1981 KZ550 oil leak on 4th cylinder
- shimvalve
21 Aug 2010 22:30 #392884
by shimvalve
1981 KZ550 oil leak on 4th cylinder was created by shimvalve
The only oil leak on my engine is on the right hand side (4th cylinder) near the head gasket. If the torque specs are good then what should i do: new gasket or o-rings? Also the only cylinder that has carbon on the piston crown and oil on the spark plug is the far right 4th. Bike has only 8,000 miles on it. Every other piston and spark plug is dry, clean, and oil free. This is a real stumper to me.
Any help from an experienced kz'er would be appreciated
- Thank you received: 2098
21 Aug 2010 22:58 - 21 Aug 2010 22:59 #392890
by Patton
Replied by Patton on topic 1981 KZ550 oil leak on 4th cylinder
Leak might be from one of several possible sources, such as tach drive, valve cover gasket, exhaust port, etc.
Need to identify exact source of leakage.
Suggest cleaning engine.
Allow to dry.
Spray suspected area with foot powder deodorant spray.
Start engine and, while idling, keep close look to see where leaking begins.
A flashlight may help.
Allow to dry.
Last edit: 21 Aug 2010 22:59 by Patton.
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
22 Aug 2010 07:18 - 22 Aug 2010 07:19 #392937
by CoreyClough
'85 GPz550(ZX550-A2)
Replied by CoreyClough on topic 1981 KZ550 oil leak on 4th cylinder
Common oil leaks on older 550 engines even with low mileage, is the side oil squirter o-rings between the head and cylinders. To do this, you'll need a new head gasket, new side o-rings, and a new valve cover gasket. Get the Kawasaki all metal gasket and o-rings for this job. It's not all that difficult, just takes time.
This isn't an oil thread, but my opinion on older bikes is never run any type of synthetic oil, unless you've replaced the gaskets and o-rings, or you plan on doing them soon. I ran "dino" oil for almost a year on one of my older engines, and when I switched to full synthetic, that's when I saw the side o-rings seeping.
Last edit: 22 Aug 2010 07:19 by CoreyClough.
- shimvalve
22 Aug 2010 08:42 #392956
by shimvalve
Replied by shimvalve on topic 1981 KZ550 oil leak on 4th cylinder
Would that also explain the isolated carbon buildup and oil on piston and plug n0.4 as well? Every other one is bone dry.
Thanks for everyone's help.
22 Aug 2010 09:01 - 22 Aug 2010 09:02 #392964
by Patton
shimvalve wrote:
Does the bike blow smoke from the exhausts?
If so, under what circumstances?
Thinking possibly a faulty valve stem seal.
Could be oil escaping past the seal into the cylinder and into the exhaust port.
Then escaping past exhaust port gasket to appear on the fins.
Last edit: 22 Aug 2010 09:02 by Patton.
22 Aug 2010 09:08 #392967
by Patton
What are compression test figures?
Especially #4 cylinder compared to the others.
Any indication of engine head having ever been removed?
Or jugs removed?
Thinking possibly oil ring on #4 improperly installed.
Or jugs removed?
