Cylinder sleeves replacement
- bikerjim
- 1986 T-type Regal
20 Aug 2010 17:20
Wondering if sleeves can be pressed out by machine shop and new ones pressed in? Just musing here.
1959 Sears moped, 49cc
50's/60's Peugeot moped, 49cc
50's Mustang motorcycle
1959 Royal Enfield Indian Chief, 700cc
1979 KZ750B, owned since new
- PLUMMEN
Re: Cylinder sleeves replacement
20 Aug 2010 17:30
toss the block in the oven heated to around 450 and listen for the clunk! :laugh:
- larrycavan
20 Aug 2010 18:32
PLUMMEN wrote:
Yes....brown slightly on both sides,season to taste and let them rest for 10 minutes before serving.....Serves 4 :laugh:
- Mcdroid
- Gone Kwackers
21 Aug 2010 02:38
Bikerjim...just to be clear, larrycavan and PLUMMEN are not kidding...the sleeves can be relatively easily removed.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- larrycavan
21 Aug 2010 05:33
Seriously, they will fall right out. I've taken them out with a harbor freight $10 heat gun before.
- MDawnz1
21 Aug 2010 23:14
They are NOT kidding ,
Good oven mitts ,
Make sure ALL the O rings are out ,
They stink ,
And I start about 325 ,
Put it on a cookie tray ,
Support the edges with something that wont burn ,
3/8 SS tubing works good ,
With the cyl upside down ,
And wait for the thunk.
Good oven mitts ,
They stink ,
1974 Z1a, still 903
- Jeff.Saunders
22 Aug 2010 05:14
the other posts missed the most important advice...
...make sure your wife is not around!
www.z1enterprises.com
Z1 Ent on Facebook,
- bikerjim
- 1986 T-type Regal
22 Aug 2010 07:01
Thanks. This is good info for the future, since the KZ750B twin has but 8500 miles. Bought it new in 1979, and if I only put another 8500 miles by bike age 60, then this info may really be moot at best. That would put me 95 years old, also. Let's see, can you mount a KZ using a cane? Kidding aside, I haven't found any sleeves advertized for this bike.
- Injected
22 Aug 2010 07:10
If you can't find them try LA Sleeve - if there not listed as a stock item they make custom sleeves any size.
If that's too expensive and you have access to a lathe just turn your own out of cast iron pipe - you only need two.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
- PLUMMEN
22 Aug 2010 08:57
Jeff.Saunders wrote:
solomrus caught hell the time we took the sleeves out of my 1327 in his wifes oven ,she came home and caught us with the smoke filled kitchen! :woohoo:the other posts missed the most important advice...
- PLUMMEN
22 Aug 2010 08:59
bikerjim wrote:
whats wrong with your sleeves with that low of miles?Thanks. This is good info for the future, since the KZ750B twin has but 8500 miles. Bought it new in 1979, and if I only put another 8500 miles by bike age 60, then this info may really be moot at best. That would put me 95 years old, also. Let's see, can you mount a KZ using a cane? Kidding aside, I haven't found any sleeves advertized for this bike.
- bikerjim
- 1986 T-type Regal
22 Aug 2010 09:32
Nothing wrong with sleeves, yet. Just looking on down the road when replacement parts, new or used, may no longer be sourced, requiring some work around. Regarding turning cast iron pipe, that is interesting. Is that the material used for sleeves? I would have thought some type of hardened alloy would have been used. If cast iron, then do you think there is a special grade cast, or is cast just cast? That could really be useful at some point. About the oven business, I installed two new convection units for the wife. Now, she could cook a roast in one, and the cylinders could be in the other at the same time. Just have to wait until she burns the roast, then no problem with the smell in the other oven.....
