I love cam bolts
  • cdulmage
  • cdulmage's Avatar Topic Author
I love cam bolts
20 Aug 2010 08:56
#392447
putting my kz1100 d1 cams back after a complete shim upgrade and you guys are right 12 f/p is to much.
I read on inserts, retapping, etc and my problem is this. What about the next time??
I noticed the cam cap bolt hole are external on the outside front and back of the head
so my thought is to drill out those 8 bolt holes flush the bottom and nut and bolt these 8 cam cap bolts.
now about the internal cam cap bolt holes.
how far down can I drill and tap? or are there other creative ideas out there
my main thought is this. The next time I pull the valve cover for what ever reason. I want the cam cap bolt to be a safe secure nobrainer (well simi nobrainer).
  • TexasKZ
  • TexasKZ's Avatar
Re: I love cam bolts
20 Aug 2010 09:01
#392449
Seems like I remember back in the day that racers replaced the bolts with studs and nuts, but I've slept since then, so I may be hallucinating.. :silly:
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
20 Aug 2010 09:09
#392451
85 inch-pounds with a tiny 3-thread tall bead of red threadlocker half way down the bolt. Tap the bolt with a rubber mallet a few times, then repeat till torque wrench clicks immediately, and always sequence tighten everything!
You can just tap larger about 1.5 cm, then use a corresponding length bolt.
Even with shorter bolts, they hold good and hard with this recipe for ever.
GL.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Motor Head
  • Motor Head's Avatar
20 Aug 2010 09:17
#392454
I think you could source some quality "Step" studs. They would be 7mm thread on the one end and the 6mm on the other. The 8mm x 6mm steps are pretty common to find, but would require as much drilling as a insert. If the 7mm x 6mm steps can be sourced, this would allow you to bolt up normally, without going out to a insert drill size. Might cost $2-3 bucks each though?
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
20 Aug 2010 10:22
#392492
Doesnt the kz1100 have 8mm. cam cap bolts?
once u time cert the thread u will never have a problem again. dont use a ft lbs torque wrench though. they are not acurate enough for small # like 12lbs. u need to use an inch lb torque wrench(144inch.lbs).
i would use blue locktight not red. blue will hold them just fine and they will be easy to remove for the next shim job.
the z1 motors have 6mm cap bolts at 9 ft lbs (81 inch.lbs)so u realy shouldnt need 12 ft lbs.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • larrycavan
  • larrycavan's Avatar
20 Aug 2010 16:41
#392569
1/4 drive ratchet with 10mm short socket and a feel for aluminum threads is the best cam torque method I've ever found ;)
Lube the threads good too...
  • PLUMMEN
  • PLUMMEN's Avatar
20 Aug 2010 17:16
#392579
no red loc tite! :S
  • Kraz1
  • Kraz1's Avatar
20 Aug 2010 17:19
#392581
