regular or high test
- bikerjim
- 1986 T-type Regal
16 Aug 2010 09:14 #391286
by bikerjim
1959 Sears moped, 49cc
50's/60's Peugeot moped, 49cc
50's Mustang motorcycle
1959 Royal Enfield Indian Chief, 700cc
1979 KZ750B, owned since new
regular or high test was created by bikerjim
KZ750B twin, 1979 model. Anyone notice any difference in using high test rather than regular grade gasoline?
- TeK9iNe
- What did you do!?!
- Thank you received: 28
16 Aug 2010 09:29 #391289
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic regular or high test
Oh boy! Here we go... :laugh:
Start with the cheap stuff and watch your mileage.
Then do a tank of mid, then a tank of high.
Repeat this process a couple times to eliminate varience, and compare: Whichever yields the highest mileage for you, is the one to use.
Depends on riding styles, engine setup, climate, etc.
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- steell
16 Aug 2010 10:39 #391374
by steell
Replied by steell on topic regular or high test
My 79 750 twin runs fine on regular unleaded so I never saw any reason to send more money on the expensive stuff.
- bikerjim
- 1986 T-type Regal
16 Aug 2010 10:56 #391391
by bikerjim
Replied by bikerjim on topic regular or high test
Thanks. I've been running regular for the past 31 years, but thought I might have been missing something as far as performance.
- bountyhunter
- Thank you received: 337
16 Aug 2010 11:26 #391399
by bountyhunter
Replied by bountyhunter on topic regular or high test
When mine was new I noticed it would miss a bit on regular but it's a California model that was jetted way too lean. I suspect a correctly tuned bike does not need it.
- DFIGPZ
- Thank you received: 122
16 Aug 2010 12:53 #391425
by DFIGPZ
1984 750 Turbo
Replied by DFIGPZ on topic regular or high test
If engine does not ping on 87 no use to use high test,the lower the octane with out pinging the better.
1984 750 Turbo
- otakar
16 Aug 2010 14:56 #391452
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic regular or high test
With age, there is carbon that builds up inside the combustion chamber and on top of the piston crowns. This will raise your compression quite a bit. plus it can cause pre-ignition due to the fact that the carbon holds heat. The best thing to do is to remove that "Crud' with combustion chamber cleaner. This can be bought from either Yamaha dealers or at any Mopar dealer. Here is a link to a previous discussion.
kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=369254
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
