valve clearances
- cdulmage
all valves messure between 2 and 4 the spec is 5 to 15
now the question
What is the + or - difference if
I get -5 shims and set the range at 5 to 10
or -10 shims for a 10 to 15 range
_
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- Jeff.Saunders
I have a question my kz1100 d1 needs shims
now the question
_
You are mixing measurement units.
0.002" - 0.006" is the recommended clearance in INCH
0.05mm - 0.15mm is the recommended clearance in MM
If you have a minimum of 2 thou clearance you are OK to run the engine. I try and set mine to around 4 thou clearance and never leave it set at 2 thou as the next time you check the valves the clearance will be UNDER spec.
www.z1enterprises.com
Z1 Ent on Facebook,
- otakar
now the question
_
I just made the presumption that he had the gap "units" right in his head. But it is a very good point, to make sure that the units of measure are not confused.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Thank you received: 2098
An uncertain about KZ1100 valve clearance specs, but for Z1-KZ900-KZ1000, FSM specifies .05mm ~ .10mm, and that some very knowledgeable folks currently recommend .10mm ~ .15mm, at least for everyday riding.
