KZ750 LTD H2 1981 REED VALVE BLANK OFFS
- angel_uk
- Wildlife Artist and adventurer by any means!
it's angie from the uk.
q1) does anyone know an online USA supplier (i live in the uk!) where i can buy some reed valve blank off plates in billet aluminium for the KZ750 ltd H2 1981 please. i've contacted A.P.E. and they have some, but they're for the 1000cc kawasaki. The dimensions are different, centre to centre.
q2)does anyone technical know the grade of the aluminium billet that they would use to make them please?
q3) have anyone ever modified the OEM covers like the one photo'd here, this my actual bike please?
q4) has anyone ever 'JB Weld' welded two pennies inside the OEM covers please, is this safe with the engine compression etc?
many thanks
angie
- MFolks
- Thank you received: 540
1. www.tpoparts.com (I used their #TPOHRSMOG kit)
2. www.kzzone.com/billet.html
- MFolks
If it were me, I'd try locally then TPO for this plate.
- MFolks
There's a machinist here named "Black Banshee" who would know more than me about Aluminum types.
He might even be able to make what you need,just give him the dimensions.
- angel_uk
thank you for your reply!
i did try kzzone and they only have a larger one in.
this is for the 1000cc not the kz750!
i will try the other company!
a big thank you mfolks!
kind regards
angie
- angel_uk
i live the uk, the home with no KZ Riders, only me i think!
i will try and find some supplier, i can't be the only one with this problem!..
many thanks
angie
- angel_uk
are you a pilot? i like a man in uniform!
i will see i can find some of this material, or a supplier for the bespoke plates in the states!
fingers crossed mfolks!
many thanks
angie
x
- Kidkawie
- I bleed premix
- Thank you received: 245
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- steell
How thick does it need to be? What's the back look like? Can't you make one out of 1/4? plate? A jigsaw with the right blade will cut 1/4" aluminum. Then just clamp the original plate to the new one and drill your holes.
And if you want it to look really good a little work with a file and then some sandpaper will do wonders.
Or get a cam cover off a 750 Turbo, I don't recall them having that stuff on them.
www.750turbo.com
- angel_uk
thanks for all of your tips!..
TPO make a CNC'd pair, time saving. only a few $ too!
they're made from 6061-T6 grade.
thanks again riders!
regards
angie
- Nebr_Rex
- Thank you received: 300
hi gang
regards
angie
Why not use a Euro spec. cam cover?
Like maybe from a GT750.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- Thank you received: 2098
...TPO make a CNC'd pair, time saving. only a few $ too! they're made from 6061-T6 grade....
Who -- what -- is TPO?
Oops, went back up and found it. Hate these senior moments.
Thanks for the link, MFolks.
