APE studs
08 Aug 2010 11:22 #389337 by fat z
APE studs was created by fat z
Hey kz'ers got a question for ya. On my 900 i need to re-torque my head cause i got a small leak on the side between the head and cylinders.the motor has APE studs in it. My question is are the studs torqued to the same amount of foot-lbs as regular bolts or do they get torqued to a higher amount. and what is that namount. Thanks.
  • DoubleDub
  • Visitor
08 Aug 2010 11:29 #389339 by DoubleDub
Replied by DoubleDub on topic APE studs
Are you torquing the studs or the head nuts?
08 Aug 2010 11:33 #389340 by fat z
Replied by fat z on topic APE studs
head nuts
  • DoubleDub
  • Visitor
08 Aug 2010 11:42 - 08 Aug 2010 11:46 #389343 by DoubleDub
I don't believe it should matter what type of studs are installed. Below is a link to the torque specs for the 900 and 1000's.
kzrider.com/index.php?option=com_kunena&...d=2&id=317332#317433
Last edit: 08 Aug 2010 11:46 by DoubleDub.
08 Aug 2010 13:06 #389356 by Injected
Replied by Injected on topic APE studs
It depends if you have both HD studs and the longer HD nuts... with both I have went as high as 55 FT LBS (race only engine)
With the nuts only and stock studs you should only be going to the recommended factory torque setting because the stock studs have a thinner diameter thru the middle section where as the HD version is thicker and made of better steel... the stock studs will strip out under high torque.
The HD nuts are stronger and won't crack under high torque loads, plus they are longer to make up for a milled deck or head so they won't bottom out on the stud end.
  • mark1122
  • Keep twisting it
08 Aug 2010 14:07 #389367 by mark1122
Replied by mark1122 on topic APE studs
i use stock nuts and ape studs. 40 to 42 ft. lbs.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
08 Aug 2010 14:29 #389368 by APE Jay
Replied by APE Jay on topic APE studs
We recommend up to 44 lbs.
  • larrycavan
  • Visitor
08 Aug 2010 17:25 #389425 by larrycavan
Replied by larrycavan on topic APE studs
Jay..you forgot to mention that's with a good torque wrench :laugh:
Seriously..... I just had this discussion on Friday night with a guy at the track with a $9 Harbor Freight torque wrench. His head gasket is leaking and he swears it wouldn't take any torque after the rebuild.
Then he pulled out his HF torque wrench ;)
  • DoubleDub
  • Visitor
08 Aug 2010 17:30 #389430 by DoubleDub
So even with the O.E. head nuts you recommend increasing the amount of torque put to the head? Is this just because the studs were the weak component previously?
08 Aug 2010 18:37 #389470 by TerryK
Replied by TerryK on topic APE studs
Make sure the stock nuts aren't bottoming out on the top of the studs. Sometimes the HD don't get seated as deep in the cases. I've seen this problem many times.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • mark1122
  • Keep twisting it
09 Aug 2010 15:10 #389679 by mark1122
Good point. thats why ape nuts have no top cap. they can be drawn down farther if u mill the head .
i actually had the opposite problem and needed to shim my studs up.
the stock studs are fine for a stock motor. the problem occurs with high compression pistons (motors ). the stock studs will stretch under load, so the ape studs are stronger to prevent stretching.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
09 Aug 2010 16:17 #389703 by APE Jay
Actually our Kawasaki nuts do have a top on them, but we have designed them so it is impossibly to mill the head far enough to make these nuts bottom out on the stud.
That is why they are called "Tall Nutz"
kzzone.com/studs.html
