APE studs
- muddy1
- 1980 Kz1000 LTD B4
09 Aug 2010 16:34 #389705
by muddy1
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
Replied by muddy1 on topic APE studs
Great, I just torqued my entire rebuild with HF torque wrenches, both inch lbs and ft lbs.....I'll let you know if it grenades......
Muddy1:dry:
Muddy1:dry:
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
- larrycavan
- Visitor
09 Aug 2010 16:54 #389707
by larrycavan
Replied by larrycavan on topic APE studs
muddy1 wrote:
I can't say for sure. Maybe your wrench is calibrated OK. I can tell you for sure his wasn't
Muddy1:dry:
- Old Man Rock
- Thank you received: 225
09 Aug 2010 17:54 #389725
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic APE studs
42 ft lbs on mine, no issues after 4200 miles...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- TerryK
- Thank you received: 3
10 Aug 2010 17:46 #389966
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic APE studs
APE Jay wrote:
I will only use Tall Nutz. Stockers are junk.
Actually our Kawasaki nuts do have a top on them, but we have designed them so it is impossibly to mill the head far enough to make these nuts bottom out on the stud.
That is why they are called "Tall Nutz"
kzzone.com/studs.html
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
