- Thank you received: 104
O-ringed Valve Cover for KZ1000??
- PLUMMEN
11 Aug 2010 21:34 #390255
by PLUMMEN
Replied by PLUMMEN on topic O-ringed Valve Cover for KZ1000??
freekz4me wrote:
works on carb gaskets also,learned that on holley float bowls years agoAn old racer trick we used to use on small block chevys was to seal the gasket to the valve cover and then use cherry chap stick on the surface going towards the head. The wax content would create a good seal but allow the gasket to come off easily for valve clearance checks. Dont know if it will work on a air cooled motor? Any kz drag racers out there that can verify? Hope it helps Grant.
- 79MKII
- Love Them Kaws!
- Thank you received: 43
12 Aug 2010 05:10 #390297
by 79MKII
The Kaw List:
Replied by 79MKII on topic O-ringed Valve Cover for KZ1000??
Wow, chapstik? Wouldn't have thought of it but sounds like it works. The cherry probably smells pretty good too! :laugh: Is the cherry better than other flavors for some reason?
The Kaw List:
