Spark Plugs
01 Aug 2010 07:26 #387386 by Buda
Spark Plugs was created by Buda
I'm running B8ES NGK's now should I run something different?
Colder plug..what do you guys think? The engine info is at the bottom of my post.
Thanks
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
01 Aug 2010 07:43 #387388 by Old Man Rock
Replied by Old Man Rock on topic Spark Plugs
Was there supposed to be an image here?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
01 Aug 2010 07:50 #387389 by drmadd95
Replied by drmadd95 on topic Spark Plugs
How are your insulators looking? Problems with fouling? Are you having problems with how the motor is running?
1979 KZ650 B (Main Ride)
1978 KZ650 D1 (sold)
1982 KZ750 (parts bike)
  • hocbj23
  • Visitor
01 Aug 2010 07:54 #387390 by hocbj23
Replied by hocbj23 on topic Spark Plugs
If the bike is set up for the street,runs ok,plugs arent fouling,why change.The stock plug covers a multitude of riding styles and conditions so I would just leave it be.bj
01 Aug 2010 08:22 - 01 Aug 2010 08:35 #387395 by otakar
Replied by otakar on topic Spark Plugs
Standard heat range should be fine. Myself I don't like NGK and I do not believe in the new fangled plugs either. They are expensive and they do not last any longer on out bikes. I much prefer ND (Denso) plugs. I started running them back in 1979 and haven't looked back since W24ES-U. I run mine with a .060 gap and Dyna coils. I sold a bunch of sets gapped to .040 and the guys love them with my high performance wires. There have been a couple of mentions about my setups in past posts.
kzrider.com/index.php?option=com_kunena&...ew&catid=4&id=351334
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 01 Aug 2010 08:35 by otakar.
01 Aug 2010 08:28 #387397 by otakar
Are you running Kawasaki ignition or Dyna ignition? If Dyna, which type? Kawasaki ignition is better than the Dyna-S but not the 2000 ignitions. Are you running resistor wires or caps or no resistance wires at all? I am running 0 resistance wires.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
01 Aug 2010 09:08 #387405 by Old Man Rock
Maybe this will help....
How to Read Spark Plugs Correctly....
kzrider.com/index.php?option=com_docman&...d&gid=460&Itemid=108
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
01 Aug 2010 09:34 #387409 by Buda
Replied by Buda on topic Spark Plugs
Kaw ignition..dyna wire and coils..the bike runs good..no plug fouling..insulators are dark like it is rich..I was just curious about what others were doing
Thanks
Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
01 Aug 2010 09:47 #387410 by Buda
no
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
01 Aug 2010 10:36 #387417 by otakar
Thanks
Buda
Gray coils or green coils?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
01 Aug 2010 10:37 #387419 by PLUMMEN
Replied by PLUMMEN on topic Spark Plugs
what bj said
01 Aug 2010 10:56 #387426 by otakar
If it is a little rich it wont hurt your bike. Your sleeves are very thin and you don't want to run any hotter than you are. With a 1170 kit in the stock sleeves you should be running an oil cooler. Make sure you are running enough ZDDP in your oil. Your oil will brake down quite fast.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
