kz650 choice of cams?!
  • 4rugrat1
  • 4rugrat1's Avatar Topic Author
27 Jul 2010 16:27
#386350
i have a 1979 kz650 d3, and i was wondering what is the hottest cam i can run with stock pistons, springs, and valves? any advice on what website that has a kz650 bolt in cam would be greatly appreciated also.:)
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: kz650 choice of cams?!
27 Jul 2010 17:23
#386358
KZ750
GPZ or larger will be lazy down low in the R.P.M. range.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • 4rugrat1
27 Jul 2010 17:28
#386364
i was thinking about the kz750 cam, but i dont want to get screwed over or something on ebay buying a used cam. i was looking online, but not much comes up, do you know of any andrews, or star cams that bolt right in? or something similar?
  • otakar
  • otakar's Avatar
27 Jul 2010 19:39 - 27 Jul 2010 19:42
#386408
I believe (but I might be wrong) that the sprocket bolt pattern on the cams is not the same between the 650 and 750. The 650 used a standard chain while the 750 used a Hi-Vo chain. I would look into that before you try anything. If they do interchange, I have a set of 750 cams that aren't doing anything. You might be able to talk me out of them.
EDIT EDIT
I guess they do interchange. They both use the same two bolt pattern.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 27 Jul 2010 19:42 by otakar.
  • DFIGPZ
  • DFIGPZ's Avatar
27 Jul 2010 19:40
#386410
try this www.megacyclecams.com/catalog/pages/page%2045.pdf
1984 750 Turbo
  • DoubleDub
  • DoubleDub's Avatar
27 Jul 2010 19:41
#386411
I thought I had seen someone mention that some of the later Kz650's also had the hyvo chain?
  • otakar
  • otakar's Avatar
27 Jul 2010 19:43
#386413
Update
They do interchange. they both use the same two bolt pattern.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • DFIGPZ
  • DFIGPZ's Avatar
27 Jul 2010 19:43
#386414
KZ 650 did not come with hivo cam chains KZ 750 and GPZ 750 had the hivo chains you can install KZ 650 cam sprockets on to KZ 750 or the GPZ 750 cams.
1984 750 Turbo
  • DoubleDub
27 Jul 2010 19:45
#386415
Well, there you go!
  • 4rugrat1
27 Jul 2010 22:10
#386446
is megacycle the only company that makes cams for the kz650?
  • otakar
  • otakar's Avatar
28 Jul 2010 05:15 - 28 Jul 2010 05:20
#386466
From what I understand, is that no one has any blanks left for the 650/750 cams. This means that all the cams are hard-welded. That is my understanding. Otherwise, Web-Cam shows a full listing of 650/750 cams. They require your old cams to weld and regrind for $500. Because of the mild performance of the 650, they also used a mild spring. You will have to install better springs with whatever cam upgrade you choose including the stock 750 cam. otherwise you will have severe valve float.
www.webcamshafts.com/index_blank.html?pages/vehicle_search.html
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 28 Jul 2010 05:20 by otakar.
  • 4rugrat1
28 Jul 2010 14:42
#386625
Okay, thats good to know. You said you have a set of cams from a 750 layin around? Do you still have them?
