- Thank you received: 225
Titanium Valves
- Old Man Rock
Performance increase, what kind of a percentage are we speaking of here? 2%, 5%, 10% increased Hp for example...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Jack
- Thank you received: 7
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
How well does bronze seats wear, when used with steel or stainless?
Do you have any idea what the weight of a stock size. Ti z1 valve is?
- APE Jay
- Banned
- Thank you received: 58
Okay Jay/Larry... give us old dogs a bone will ya.... :laugh:
That depends on a lot of things. Generally the motor will RPM 500 more before valve float with Ti valves. How much more power will that 500 extra RPM make? That is the question.
Also, with cams over 480 lift the valves have to get larger. They reach a point where they are just heavy. I don't like to see a valve bigger than 40 mm in stainless in a race motor with over 480 lift.
So to answer the question, Ti valves don't make any more power. it is what they will allow you to do such as increased RPM and valve size and cam lift that will make the extra power.
So as far as a street bike goes, You have a 1260 motor with 435 cams.... Will Ti valves help it? No. Will it just wear the valve faces out sooner...Yes.
- Old Man Rock
Basically goes in what I was understanding....
Unless your building a seriously whacked performance engine, drive train, gearing etc for racing.... Not worth the extra $$$$ for 99.9% of us re-building these old KZ's....
Stock or mild performance builds this is just not worth the cost with minimal gains this concpet would provide...
Thanks for the clarification.....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- larrycavan
- Visitor
Most times I toss the Ti in favor of KW stainless with their springs, retainers and spring seats for ATV heads.
Put and aftermarket cam like say a stage 1 HotCams cam in an ATV motor with stock springs and the valves will tulip in no time....Even the steel OEM valves.
Look at the spring pressures they run in the cars these days... :ohmy:
- APE Jay
- Banned
Next time you do onew of those 450s, use my stuff and let me know what you think.
www.bigborethumpers.com/crfheadkits.html
- larrycavan
- Visitor
Larry;
I'll give it whirl Jay
- nads.com
- Thank you received: 20
