valve clearances no good. now what?
- asevans
valve clearances arent to spec.
heres my numbers.
intake 1-4 .007,.007,0 clearance,.003
exhaust 1-4 .005,.008,.007,.005
spec is .002-.004
only one is in spec. intake #4
ive never done this before. i was reading the manual and it doesnt seem hard.
whats up with the valve that doesnt have any clearance. seems strange. i checked it then turned it and checked it again to make sure.
do i need to buy the special tool? the valve lifter tool. also were do i get shims at? do the dealers still sell them?
i appreciate any help.
thanx
1976 kz900 Mostly stock
1978 Z1-R Project
- bountyhunter
- Thank you received: 337
Are you sure about the .002 - .004" spec range? The reason I ask is that's the spec for my 750 twin, but I thought the four cyclinder bikes had wider specs because the internals get hotter. I could be wrong but I thought they were supposed to be wider than that.
If the shims are on top, you need the compressor tool to be able to change shims without pulling the cams. If the shims are underneath, tool won't help (the cams have to come off).
- asevans
the clymers says .002-.004
the shims are on top. ill have to order the tool. i looked on Z1 and they have everything i need. should of looked on there before i asked. oh well. just have to pay shipping twice because ill have to get the tool, remove old shims then order new shims. oh well.
1978 Z1-R Project
- PLUMMEN
- Thank you received: 104
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- PLUMMEN
- PLUMMEN
try swapping the really tight shim for a really loose one from another valve and see what that does for both of themalright. my wife thinks im crazy but i just like messing with my KZ. plugs inconsistent so im checking things mentioned by people on here that know more than me.
heres my numbers.
spec is .002-.004
thanx
- otakar
www.z1enterprises.com/catalog.aspx?pid=KPEN1B
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Thank you received: 2098
- asevans
thanx
1978 Z1-R Project
- BSKZ650
wheres your sense of adventure? :woohoo:
This is from the guy who looked like he was 8 mths pregnant, after he had a adventure:ohmy:
- bountyhunter
The trick is to carefully measure and record all clearances. Take all the shims out (keep them in order) and that lets you calculate the shim you need for each. In most cases, you can swap shims around and don't have to buy a shim for every valve out of spec.thanx for all the advice. i just ordered the OEM tool. i need to keep it as simple as possible. last time i screwed around in here i busted a cam cap bolt.
thanx
