- Thank you received: 391
TRANSMISSION BEARINGS
- Motor Head
21 Jun 2010 18:32 #377396
by Motor Head
TRANSMISSION BEARINGS was created by Motor Head
82 KZ1000K2 LTD.
How many bearings in the transmission are sealed with factory grease and not lubed bu engine/ trans oil??
If there are then where which ones??
I think from looking on the web for bearings that the counter shaft behind the sprocket is possibly a sealed bearing from factory. Right???
- larrycavan
- Visitor
21 Jun 2010 18:54 #377408
by larrycavan
Replied by larrycavan on topic TRANSMISSION BEARINGS
Motor Head wrote:
All bearings are internally oiled. There are oil passages in the case. There's a seal for the countershaft that's in the trans cover and an O ring that goes behind the collar.
82 KZ1000K2 LTD.
- Motor Head
21 Jun 2010 19:00 #377410
by Motor Head
Replied by Motor Head on topic TRANSMISSION BEARINGS
Thanks, that is what I thought looking at the parts diagram and the external covers on the bike. Just wondering where this noise is from, sounds Just like a Dry bearing, and is louder in 4-5th gears. Pull in the clutch and coast and it still is there, although less. Many of these bearings prone to failure, when pan only showed some ones additive pull ring and some clutch material? Both of the wheels turn nice and free with no noises, chain has been adjusted and lubed and lubed ...........
- Thank you received: 797
22 Jun 2010 14:11 #377585
by 531blackbanshee
Replied by 531blackbanshee on topic TRANSMISSION BEARINGS
lift the back wheel off the ground(centerstand) remove the chain and sit down by the countershaft(might help to remove the countershaft cover).now turn the countershaft (sprocket)with your hand and listen.buy doing this you will be turning all four bearing in the transmission and should be able to hear any noise(crunching/grinding).if no noise turn the back wheel and listen for noise.using this method you should be able to locate the problem bearing.
bad bearings can look like this
hth,leon
hth,leon
- Motor Head
22 Jun 2010 15:16 #377595
by Motor Head
Those are TOAST!
Pulled and inspected, all good. Chain is worn, ordered new drive components from Z-1. Now got to wait, but I'm confident in this will fix the noise.
