KZ1000 Dyno Results!
- PLUMMEN
Re: KZ1000 Dyno Results!
21 Jun 2010 17:53
nads.com wrote:
:woohoo:beefsquasher wrote:I have a 1015cc kit in mine and the timing has to be set way back to run right. I don't think the stock marks are even close with a faster burn going on. Have you tried backing the timing down? That buzz everyone talks about is evident in my engine only when the timing is too advanced. Can you drop from 5th to 3rd at 85 and go ZOOOOOOOOOOOT or does it just go VIBRATE EAAAARRRRRR on the handle grips? HUH?:woohoo:No sniffer, sorry.
Mikuni RS34.
Stock Float Height
Mixture screws 3/4 turn out.
17.5 pilots
125 mains
9DZH01 Needle on 2nd clip
I am going to change to a fatter needle jet - bike tends to heat up and ping at 1/4 to 1/2 throttle.
-Dave
- hocbj23
21 Jun 2010 17:57
Hm-m-m.I believe yon cowgirl got her Zoot mojo workin and yon cowboy broke the vacuum on his seat pucker.Good one Plummen.bj
- nads.com
- mark1122
- Keep twisting it
28 Jan 2012 19:23
what did they do between runs to make improvements ?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
