KZ1000 Dyno Results!
- beefsquasher
19 Jun 2010 13:19
Got my bike dynoed on a Dyno-Jet eddy-current brake dyno (not the inertia type).
Results? 103.5 HP, 66.8 TQ.
You can really see the big step at 5500 where the cams kick in.
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- supercharged
Re: KZ1000 Dyno Results!
19 Jun 2010 15:27
nice - never had my KZs Dyno'd...
What is you set-up. Assuming stock was about 92bhp.
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- PLUMMEN
19 Jun 2010 15:31
the best stock motored 1000 ive seen with 26s and a header was around 75 at rear wheel
- larrycavan
19 Jun 2010 17:05 - 19 Jun 2010 17:08
PLUMMEN wrote:
I'm confused :huh: Is that DJ chart for a stock KZ?
I don't see any RPM reading, only MPH.
Last edit: 19 Jun 2010 17:08 by larrycavan.
- testarossa
19 Jun 2010 17:16
Must be the bike in his signature. Sounds about right for a 1075 with cams, 34's and a 4 into 1.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- beefsquasher
19 Jun 2010 17:45
Not stock at all.
Here's the buildup: kzrider.com/index.php?option=com_kunena&...w&catid=11&id=373210
-Dave
-Dave
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- PLUMMEN
19 Jun 2010 17:47
yeah i realize that,just pointing out the vast improvement over stock motor with pipe
- beefsquasher
19 Jun 2010 17:48
Only difference to that post is that the lobe centers are at 107.5 now. The valves were getting just a wee bit too cozy with the pistons at 105. There was no contact but basically zero clearance. Redline is set at 9500 on this run. The throttle was clearly opened too quickly at too low an rpm at the bottom of the run (about 2200 rpm).
-Dave
-Dave
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- larrycavan
19 Jun 2010 18:57 - 19 Jun 2010 19:12
[file] beefsquasher wrote:
I looked at the build specs in the link you provided. Now it makes sense...
Do you happen to have the numbers with RPM ?
Also watched our .mpg video. Sounds real good. Nice & crip throttle response. What Tach is that you have? I like that
Larry C
-Dave
Larry C
Last edit: 19 Jun 2010 19:12 by larrycavan.
- beefsquasher
19 Jun 2010 19:12
Sorry, no RPM numbers. Apparently, running non-resistor plugs scrambles the hell out of the rpm sensor on the dyno.
I used gearingcommander.com to figure out my RPMs.
-Dave
-Dave
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- beefsquasher
19 Jun 2010 19:23
Tach is Autometer Pro-Cycle.
procycle.autometer.com/CatalogGaugeDetail.aspx?gid=134
Electronic tach. It was a little jumpy just reading off one coil, so I wired in two diodes and ran it off signals from 2 coils, then told it to act like it was reading a twin.
No cables, wobbly needles, or messy oil leaks from the tach port here!
-Dave
-Dave
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- Ituen
- Rider
20 Jun 2010 08:38
Nice numbers! I think I'm going to need a bigger motor.
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
