KZ1000 Dyno Results!
  • hocbj23
  • hocbj23's Avatar
Re: KZ1000 Dyno Results!
20 Jun 2010 08:59
#377015
Naw.Just remember 1972-3 Yamahammer RD350's.28 hp or so bone stock and they would blow most anything away at the time,including the then awesome 750 Hondas.Why? Lite weight and GREAT handling.They would do a head over in 1st,2nd gears if u were not an experienced rider.A little weight control,some handling mods and most stock KZs have more than enough.Lol.bj
  • TexasKZ
  • TexasKZ's Avatar
20 Jun 2010 13:17
#377074
Was a tailpipe sniffer hooked up? I'd be interested in seeing what the a-f ratio looked like.
  • beefsquasher
  • beefsquasher's Avatar Topic Author
20 Jun 2010 16:43
#377100
No sniffer, sorry.
Mikuni RS34.
Stock Float Height
Mixture screws 3/4 turn out.
17.5 pilots
125 mains
9DZH01 Needle on 2nd clip
I am going to change to a fatter needle jet - bike tends to heat up and ping at 1/4 to 1/2 throttle.
-Dave
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
  • larrycavan
  • larrycavan's Avatar
20 Jun 2010 17:50
#377116
beefsquasher wrote:
No sniffer, sorry.
Mikuni RS34.
Stock Float Height
17.5 pilots
125 mains
-Dave
Dave,
Before you spend more money on the carbs, check you gas cap vent and make sure it's really venting properly. Chances are it's fine but hey...ya never know and it cost you nothing but a little time.
You would not believe how much time a guy I know put into his RS34's with jetting....only to finaly figure out his gas cap was the problem.
  • nads.com
  • nads.com's Avatar
20 Jun 2010 22:44
#377203
beefsquasher wrote:
No sniffer, sorry.
Mikuni RS34.
Stock Float Height
17.5 pilots
125 mains
-Dave
I have a 1015cc kit in mine and the timing has to be set way back to run right. I don't think the stock marks are even close with a faster burn going on. Have you tried backing the timing down? That buzz everyone talks about is evident in my engine only when the timing is too advanced. Can you drop from 5th to 3rd at 85 and go ZOOOOOOOOOOOT or does it just go VIBRATE EAAAARRRRRR on the handle grips? HUH?:woohoo:
  • hocbj23
  • hocbj23's Avatar
21 Jun 2010 08:58
#377261
nads.com wrote:
beefsquasher wrote:
No sniffer, sorry.
Mikuni RS34.
Stock Float Height
17.5 pilots
125 mains
-Dave
Do that too many times and it wont go ZOOT, it will go HICCUP and eat a couple of valves.Lol.bj
  • beefsquasher
21 Jun 2010 12:48
#377296
Gas cap vents fine. I have the timing backed off about 6 degrees from stock - way less vibration, and motor runs cooler. I'm pretty sure its the mixture at that throttle opening. If I go 100, the motor runs much much much cooler, the throttle is open wider, as soon as a drop back to 1/4 throttle, even if I'm still going fast (with more airflow over the fins), I can actually see the motor pick up heat and start pinging.
I have a thermocouple on the cam cover. On a nice 85 degree day, it reads about 200f cruising backroads, on and off the throttle. 210f-220f really getting on it on some nice 2-lane 70-110 mph. If I just sit on the highway at 75-80mph, temp shoots up to 245f-250f in about 2 minutes.
I have all the parts I need for an oil cooler, I just need to fab up a mount. So I'll get that installed soon enough.
Also, the darn thing still leaks oil from the base gasket. I pulled the top end again, and this time replaced the base gasket with an OEM Kawasaki part, painted Threebond semi-drying case sealant around each stud and the cam chain tunnel. What gives?
-Dave
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
  • porchev914
  • porchev914's Avatar
21 Jun 2010 13:20
#377300
hocbj23 wrote:
nads.com wrote:
beefsquasher wrote:
No sniffer, sorry.
Mikuni RS34.
Stock Float Height
17.5 pilots
125 mains
-Dave
I think he's talking about ignition timing, not cam timing. The valves will stay just where they're at B)
FRANKEN Z!
  • hocbj23
  • hocbj23's Avatar
21 Jun 2010 14:56
#377318
Wrong notion.My reference was slamming a bike into 3rd gear from 5th gear at 85 mph.not sure that is a healthy thing to do, but hey,what do I know.bj
  • PLUMMEN
  • PLUMMEN's Avatar
21 Jun 2010 17:36
#377369
i hope youve got a firm grip on the barsa and knees locked tightly against the side covers when attempting that one! :woohoo:
  • PLUMMEN
  • PLUMMEN's Avatar
21 Jun 2010 17:37
#377370
-Dave
copper coat
  • hocbj23
  • hocbj23's Avatar
21 Jun 2010 17:52
#377373
u betcha-plus a firm pucker on the seatcover as well.bj
