sleeve installation
  • Darmah
  • Darmah's Avatar
Re: sleeve installation
15 Dec 2021 21:28
#859155
I love watching Allan Millyards videos. He's an absolute genius and makes everything look so easy. Check out his 1600cc V8 Z1 and other brilliand projects.
  • Ian_B
  • Ian_B's Avatar
18 Dec 2021 07:21
#859255
It's interesting to see which engines he picks to work on. I think he started with the Kawasaki 2 stroke triples, and then moved on to 900's / 1000's. To my knowledge, he hasn't done the same to what i thought would be the perfect motor for turning into a straight 6, a Z650. Then I realised that the problem would be with the crank; the 2 strokes and the 900/1000's all had pressed together cranks, the 650 (and damn Kawasaki to hell for this) is a solid forging with splt conrods. This makes the conversion a whole lot more complex!
A 1000/6 is on my long term "to do" list. The crank is still do-able, but a lot more work than it would otherwise have been.
Whatever, his videos are true genius.
  • u.k. Dave
  • u.k. Dave's Avatar
03 Jan 2022 10:16
#859977
A friend if mine steam cleaned his block outside a few years ago and once done he turned round to switch off the machine only to hear a loud clanging noise behind him. Spinning round quickly to see what the noise was he was horrified to see three if his liners had just dropped out!
