- Thank you received: 797
Transmission noise
27 May 2010 14:21 #371427
by 531blackbanshee
Replied by 531blackbanshee on topic Transmission noise
that bearing has a circlip around the circumferance that means you have to split the cases.
the circlip fits in the groove and forces you to have to split the cases.
- prosserk
28 May 2010 11:39 #371654
by prosserk
Replied by prosserk on topic Transmission noise
ya, i looked in the book and saw that. the bike is already torn apart, now i'm just waiting on parts. and pat, you need to find something to do while you are at work! haha
- prosserk
28 May 2010 11:40 #371655
by prosserk
oh ya, is there any little things i need to watch for when i split this apart?
- timebomb33
- Thank you received: 10
28 May 2010 12:11 #371659
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Transmission noise
there are holes in the bottom cases that are threaded the oppostite way. 2 at the front of the engine and one at the rear. they are blind holes you thread in your 8 mm case bolts after you have removed all the case bolts and tighten them down evenly they will seperate the cases. but first remove the sprocket and transmission cover also the kicker and clutch and [points housing. the top end can stay in one piece and the rotor can stay on the crank also all you shifter mechanisims can stay they don't have to be removed. there are i think 5 or 6 6mm bolts around and under the starter in the top half of the case that have to come out and of course the oil pan and filter housing has to come off. remember you can leave the entire top end together the crank stays in place dont even pull the center main cap.if you use the bolt method you should not even have to use pry bars or hammers to get the cases apart.
- patmann
- Thank you received: 6
01 Jun 2010 06:43 - 01 Jun 2010 06:46 #372561
by patmann
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
Replied by patmann on topic Transmission noise
prosserk wrote:
Kyle,
I have MANY other KZ manuals too that might be of help to you.
Let me know if I can help in anyway.
And for your information...I am working. Or at least getting paid. :whistle:
Kinda' like you @ your work
Pat
Kyle,
Pat
Last edit: 01 Jun 2010 06:46 by patmann.
