Transmission noise
- prosserk
22 May 2010 09:58 #369795
by prosserk
Transmission noise was created by prosserk
so i bought a KZ 900 a few months ago and have put about 500 miles on it with no problems. then i had my clutch cable break. so i replaced it and also changed my oil at the same time. after doing this i went on a 150 mile ride and it started to make a weird noise. it sounded like a squeeling noise, but it wasn't happening all of the time and it did not make a difference what RPMs i was at. then a few days later i went for a ride and got about ten miles and it and when i was riding something happened and it felt like someone put the breaks on. when i got stopped it looked like smoke was coming out of the oil breather. when i tried to move again it almost felt like there was a brake on, but the engine would still sit there and run fine and i could shift through the gears. then when it cooled down i could ride it again but it would still make the noise randomly. i was just wondering if anyone had any ideas. thanks
- timebomb33
- Thank you received: 10
22 May 2010 10:14 #369804
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Transmission noise
how tight is your drive chain it could be the countershaft bearing failing.
- hocbj23
- Visitor
22 May 2010 13:02 #369834
by hocbj23
Replied by hocbj23 on topic Transmission noise
did u adjust the clutch cable so that it had the proper amount of play in it at the bar lever and at the release bearing.If too tight u could have fried ur clutch.bj
- prosserk
24 May 2010 10:37 #370471
by prosserk
Replied by prosserk on topic Transmission noise
ya i know i adjusted the cable right. i have a shop manual and i did it exactly like it said to in the book. my drive chain is pretty loose. probably to the point that i need to tighten it, but i will check to see if the bearing is getting bad.
- Motor Head
- Thank you received: 391
24 May 2010 11:23 #370485
by Motor Head
Replied by Motor Head on topic Transmission noise
I think I would pull it apart and hope that you haven't spun a bearing in the case bore. It won't get any better it will just get worse and cause more damage like striped gear teeth.
- Sandy
- Fly High,Tony
- Thank you received: 13
24 May 2010 11:47 #370490
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Transmission noise
What did you use for oil when you changed it?
1977 KZ1000 A-1
- patmann
- Thank you received: 6
24 May 2010 12:54 - 27 May 2010 11:48 #370517
by patmann
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
Replied by patmann on topic Transmission noise
Kyle,
Has it gotten any better or worse since the time I rode it?
All, I rode it once after this started. It only made the noise, no problems/ slowing down. Once it sounded as if it was on the left ( stator ) side , the next time on the right side.:huh:
Couldn't really tell which side for sure the noise was coming from since he's running a open Kerker or Mac on it And it was a quick/short 1/2 mile ride.
I loaned him a factory KZ 900 manual, and rode it after the clutch adjustment. The clutch felt fine to me when I was on it.
But as I said, this is THE PLACE to have it figured out at;)
Pat
Pat
Last edit: 27 May 2010 11:48 by patmann.
- patmann
25 May 2010 06:29 #370738
by patmann
Kyle,
What type/brand and weight of oil did you use when it was changed?
- prosserk
27 May 2010 11:24 #371377
by prosserk
the oil was SAE 10w40, but it was a honda brand. i then dumped that out hoping that was the problem and put in regular pennsoil 10w40 and it seemed to make it better, but it is still making the noise just not as often.
- Jack
- Thank you received: 7
27 May 2010 12:14 #371393
by Jack
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Replied by Jack on topic Transmission noise
You might want to check your clutch pushrod and ball.The squealing noise could be the pushrod welding itself to the ball -if the clutch adjustment is out of whack there is not enough free play between the pushrod & the ball.Hope this helps.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- prosserk
27 May 2010 12:38 #371400
by prosserk
It's the output shaft bearing. does anyone know if i can change that bearing without splitting my case?
- patmann
27 May 2010 13:01 #371411
by patmann
Kyle,
How did you figure out it's the output shaft bearing??
You can refer to the manual I loaned you for teardown. And I have MANY others IF need be.
And da' BOZ is a great guy when it comes to being anal about tearing down and putting back together. Got'a love him.
But you already know that, don't you..???
Pat
Pat
