1977 KZ1000 Head-What's a good mileage to Repair?
20 May 2010 08:07 #369225 by EricHa
As a general rule, how many miles can you get out of a KZ1000 head before it needs a valve job? I do believe that they had better guides than the 900's. Is a head with 25,000 to 30,000 miles still good to go for a while?
1977 Kawasaki KZ900A5
1975 Honda CB550K
1996 Ducati 900SS CR
20 May 2010 08:35 #369234 by otakar
If the valves have been shimmed properly on a regular basis over the years, police departments get 75-80k out of the top ends.The problem are your valve stem seals. They get hard and start leaking with such a long exposure to heat and oil.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
20 May 2010 08:42 #369235 by EricHa
Thanks otakar. Wow, so probably double the mileage that you'd get from a Z1 head? I just picked up another KZ900 project with 52,000 miles, head needs a thorough going over. I may just grab a used 1000 head for now and run it. Put new seals in of course.
1975 Honda CB550K
20 May 2010 08:52 #369238 by BSKZ650
with 52k on it, I would be looking real close at the rings pistons and cyls, since you are taking the head off not that much more to do the full top end and you prob wold want to include the timing chain guides as well, they get hard and can cause problems down the road
77 ltd1000, current rider
76 kz900, just waiting
20 May 2010 09:04 #369244 by EricHa
Yeah, the whole top end is off, and the timing chain stuff is indeed disentegrating. I am going to check the bores tonight. I figure that they'll be out of spec, I just wonder if they're too far gone to re-ring. My other KZ900 project was right at the spec limit of cylinder bore with 23,000 miles.
I didn't want this bike to take away resources from the first project, but it's inevitable I guess!
1975 Honda CB550K
20 May 2010 09:56 #369248 by PLUMMEN
depends entirely on how well its been maintained
20 May 2010 10:23 - 20 May 2010 10:35 #369258 by Patton
Wouldn't suspect any difference in top end longevity among Z1, KZ900 or KZ1000.
:unsure: How was valve guide on KZ1000 better than Z1 and KZ900?
Good Fortune! :)
Last edit: 20 May 2010 10:35 by Patton.
20 May 2010 10:54 - 20 May 2010 10:56 #369270 by bountyhunter
Replied by bountyhunter on topic 1977 KZ1000 Head-What's a good mileage to Repair?
Those were the cop bikes used throughout Kali back in the 80's. The machine shop that did my head also serviced their fleet. They told me the average mileage for a service bike was about 20k miles between head jobs. City riding is worst for a bike. Mine had about 45k at the first valve job, the machinist thought I was bringing it in for it's second valve job and couldn't believe it was the first.
Last edit: 20 May 2010 10:56 by bountyhunter.
20 May 2010 11:41 #369286 by EricHa
According to Dave Marsden:
In the original Z1 cylinder head, the eight valves moved in bronze guides that were pressed into the head and secured by small circlips. These guides proved to be too soft for the job and were one of the few mistakes Kawasaki engineers made. They were later modified to a cast iron item.
1975 Honda CB550K
20 May 2010 12:48 - 20 May 2010 14:23 #369314 by Patton
Yes, but from the info as presented by Mr. Marsden, am thinking the change from brass to iron was done during the 1973 Z1 model run (no clue as to engine number), so later '73 Z1~'76KZ900 would have the iron guides. "Were later modified" is mentioned in the '73Z1 engine chapter, without further reference in later chapters on '74Z1~'76KZ900 or about KZ1000.
Except for early '73Z1 heads with brass guides, am thinking subsequent Z1 and KZ900 heads have the iron valve guides. (But not positive about this.)
Good Fortune! :)
Last edit: 20 May 2010 14:23 by Patton.
20 May 2010 12:53 #369318 by Patton
Interesting ---
kzzone.com/valves.html
HIGH PERFORMANCE BRONZE VALVE GUIDES
APE valve guides are designed to take the abuse of today's modern high horsepower engines. They are made from special bronze alloy to resist wear and heat. No other valve guide that you can buy will out-perform APE guides. Fact is we supply our guides to nearly all of the top cylinder head shops. Major police departments use them in their patrol bikes which see severe use.
APE guides are precision machined with the bores finished to size.
They are designed to fit lower in the head to clear high lift cams, and use APE seals or factory OEM seals. Sold in sets of 16
Good Fortune! :)
20 May 2010 13:05 #369322 by BSKZ650
Patton wrote:
Interesting ---
Good Fortune! :)
wheres Billy Mays when ya need him,,,lol,,and I know hes gone
