"J" Engine, Valve Clearances and Ticking Question
- MentalMike
- God Bless America!
Today I again checked the valve clearances and they are:
1
2
3
4
Exhaust
.012
.011
.008
.010
Intake
.009
.014
.008
.008
Spec clearances for this Engine are: .005 - .015
These clearances are very close to what I got after I put the top end back on in January.
My question is this:
Even though valve clearances are within spec, and yes a couple could be fine tuned, would the ticking be caused because there is somewhat of a swing between the clearances?
I'm running out of ideas. I know some ticking on certain bikes can be normal, but like I said, this is louder than I would expect.
What am I missing? Would the solution be to simply tighten up the clearances so they are more in line?
Thanks fellas.
I swear to God, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity.
1976 Kawasaki KZ900
1978 Kawasaki KZ1000A
1978 Kawasaki KZ650 C
1984 Kawasaki ZN1100 LTD
1985 Kawasaki ZX900A2 GPZ (2)
1985 Kawasaki ZL900 Eliminator
2013 Kawasaki C14 Concours
- PLUMMEN
- Thank you received: 104
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Get a new set of feeler guages just to be sure, and make all your clearances around the .10 mark.
Be certain you are pressing the feeler guage flat against the shim before dragging it back and forth under the cam heel.
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
- Thank you received: 225
Is this (.005) correct?
KZ900 & Early 1000's @ .05mm... I get that but .00 5
up to .015... Whoa, interesting...
Learn something new everyday.... Cool!
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- 9am53
- homebrew, and some bbq
- Thank you received: 3
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- Old Man Rock
Exhaust
.012
.011
.008
.010
Intake
.009
.014
.008
.008
Hopefully just a miss print...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 9am53
'84 GPz900r
'71 CB350
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- TeK9iNe
.05mm roughly .002 inch
.10mm roughly .004 inch
.15mm roughly .006 inch
etc. etc. etc.
If his error is a typo in mm, then were ok.
If he is using inches, those clearances are WAY too large!
So... whats up! :laugh:
Inches... mm...
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
well, assuming he did make them all way too tight, that wouldn't explain the ticking.
Correctomondo...
Way too tight would be dead silent, as he lost compression and his exhaust valves started to fry :blink:
They tick when the gap is too large only.
Peace!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
.05mm - .15mm or .002 - .006 inch for spec...
Exhaust
.012
.011
.008
.010
Intake
.009
.014
.008
.008
Example:
.012" = .3048mm thus double the clearance gap spec.
.012mm = 0.0005" extremely tight clearance gap
.008" = .2032mm large out of spec clearance gap.
.008mm = .0003" tight clearance gap.
Either way you look at it, the numbers don't jive to spec.
As mentioned, too large ticky-ticky.... Possibly spit a shim pending which measurement system was used...
Too tight, not good on the valves...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- MentalMike
I think we are having unit conversion misunderstandings, inches are bigger than millimeters...
Yes these are the correct specs, I didn't copy them right.
1976 Kawasaki KZ900
