- Thank you received: 104
Compression question
- PLUMMEN
- KZCool
check your timing
Do you mean the timing chain that goes around the cam and top rotors?
1976 KZ750 hardtail
- BSKZ650
- Thank you received: 14
PLUMMEN wrote:
check your timing
prob meant ignition timing
77 ltd1000, current rider
76 kz900, just waiting
- KZCool
1976 KZ750 hardtail
- PLUMMEN
- PLUMMEN
how far above/below was it?ok well i took the valve cover off, aligned the TDC mark on the crankshaft. the arow on the rear sprocket was flush with the cylinder head and the 32nd pin in the chain was were it was supposed to be on the front sprocket, but the front arrow wasn't flush with the cylinder head like my manual shows, any thoughts. And why would the ignition timing be a problem for compression if it wont start?:blink:
- DoubleDub
- Visitor
I second this question - on my 900 there is pressure from the valve springs that causes the hash mark not to line up perfectly until the chain is tightened and I turn the engine so that the camshaft turns an entire rotation.
Please note that not everyone agrees that this is best practice as if things are off a valve and cylinder head might touch while turning the engine over.
- KZCool
i've also already trightened it ad turned it a few times with the crankshaft and a 17mm wrentch. ill post a picture
1976 KZ750 hardtail
- KZCool
- KZCool
1976 KZ750 hardtail
- KZCool
1976 KZ750 hardtail
