- Thank you received: 1
Compression question
- KZCool
1976 KZ750 hardtail
- PLUMMEN
- Thank you received: 104
- nads.com
- Thank you received: 20
- Old Man Rock
- Thank you received: 225
Check cam lobe orientations and cam sprocket markings for correct tooth count and lobe orientation...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Motor Head
- Thank you received: 391
- Thank you received: 2098
Easy enough to evacuate, but would not attempt to start and run engine until checking for fuel contamination of crankcase oil, and taking whatever corrective measures may be needed.
- kawsakiman
- Thank you received: 6
beat me to it again.
this is the only logical answer.
damn you patton!
:laugh: :laugh: :laugh: :laugh:
Isn't it way past bedtime?
- KZCool
1976 KZ750 hardtail
- Thank you received: 2829
I have had a lot of problems with carbon in my cylinders because I always have to have the choke on... /quote]
You need to fix that problem Running with the choke always on will lead to bigger problems (if fact, it may have already). Regarding the compression; why not simply do a compression check on each cylinder? Ed
- BSKZ650
- Thank you received: 14
with the plugs removed does it turn over? by either the starter or kick
as said before pull the valve cover and also the side cover and try to rotate the engine backwards if it wont turn over.
77 ltd1000, current rider
76 kz900, just waiting
- KZCool
1976 KZ750 hardtail
