I need some exhaust help
20 Apr 2010 17:51 #362031 by djturnz
I need some exhaust help was created by djturnz
82 KZ750(4) LTD
My exhaust is 4 into 2 with a cross over.
I want to pull my stock mufflers and use internal baffles and then have custom pipes done. I haven't pulled the mufflers yet, but I wanted to look for the baffles now. I used my calipers and measured the OD of the pipe before the muffler as 1.18". I assume that gives me a 1" pipe ID? Is that right? That seems awful tiny.
All the baffles I've seen start at 1.5" and go up.
I assume that someone has pulled their stock pipes, is it really 1.18 OD?
I haven't pulled them yet because I have inspection coming up in a week.
Thanks in advance.
1982 KZ750 (4) LTD
20 Apr 2010 20:22 #362060 by jeffasaki
Replied by jeffasaki on topic I need some exhaust help
Just get rid of that rusty old POS and get a 4 into 1 sounds ands perfomes better
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
20 Apr 2010 21:16 #362064 by bountyhunter
Replied by bountyhunter on topic I need some exhaust help
Before you cut on the stock pipes: if they are in good shape, they are worth a lot of bucks. Restorers are always looking for them.
21 Apr 2010 04:00 - 21 Apr 2010 04:06 #362088 by djturnz
Replied by djturnz on topic I need some exhaust help
Cut them off? They look to me clamped on.
And they aren't rusty. The only part thats rusted is the screw and bolts holding the heat shield on that covers where the muffler attaches.
1982 KZ750 (4) LTD
Last edit: 21 Apr 2010 04:06 by djturnz.
  • RaeRae
  • Smart @ss white girl!
21 Apr 2010 05:59 #362097 by RaeRae
Replied by RaeRae on topic I need some exhaust help
Then how come I can't get rid of mine? :unsure: Guess, I'll have to try selling on ebay? I've had on CL for now....
OWN:
82 KZ550 LTD (work in progress)
81 550 GPz (work in progress)
81 KZ550A (parts bike)
91 750 Honda Nighthawk
WANT:
One in every size and color! =)
Euharlee, GA by way of Glendale, AZ
21 Apr 2010 06:43 #362105 by JMKZHI
Replied by JMKZHI on topic I need some exhaust help
djturnz wrote:
Cut them off? They look to me clamped on....
Someone already cut off the stock mufflers & clamped on those.
21 Apr 2010 07:30 #362119 by djturnz
Ok, so these aren't stock? What are the stock ones supposed to look like on the LTD? They are ugly as hell, so I assumed they were factory.
1982 KZ750 (4) LTD
21 Apr 2010 07:46 #362122 by djturnz
Assuming the header part is stock, what is the ID of that pipe supposed to be? I need baffles.
What about those Harley Coil baffles?
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...ME:X:RTQ:MOTORS:1123
They are 1.75". I could just cut off a couple coils to get down to 1" or whatever it is.
1982 KZ750 (4) LTD
21 Apr 2010 08:19 - 25 Apr 2010 07:10 #362126 by JMKZHI
The photo below is a 1980 KZ750-Ltd w stock mufflers which are the same the later H-models. You could reference the diagrams at Kawasaki.com to see how they're constructed.
You're trying to fit baffles into the pipes where the stock mufflers were cut off?
Why not put the baffles inside the new pipes you plan on installing?
Last edit: 25 Apr 2010 07:10 by JMKZHI.
21 Apr 2010 08:51 #362134 by djturnz
I could do that, though I think I'd still be in the same boat. A 1" pipe ID. 1.18" OD would allow for maybe a 1.25" OD pipe. I still won't find a 1.18" baffle.
The header pipes are 1.25 I think, so why is it necked down so far? two pipes at 1.25 necked together at 1". That seems odd. Or is this to force the excess gasses through the crossover pipe?
1982 KZ750 (4) LTD
21 Apr 2010 10:27 #362149 by JMKZHI
I didn't realize you were going to run teeny tiny pipes all the way. It seems like the easiest thing to do would be to simply find matching pipes & baffles in whatever size, then install that.
21 Apr 2010 10:58 - 21 Apr 2010 11:03 #362154 by bountyhunter
Then they are not stock. Somebody already took the hacksaw to them. Those mufflers look like the ones JC Whitney used to sell.
Last edit: 21 Apr 2010 11:03 by bountyhunter.
