CROSS THREADED PLUG
- scubarod
20 Apr 2010 12:12 #361966
by scubarod
CROSS THREADED PLUG was created by scubarod
I HAVE CROSS THREADED ONE OF MY PLUG HOLES IN MY HEAD ON MY KZ1OOP.IS IT TIME FOR A NEW HEAD OR SHOULD I TRY TO HELICOIL IT OR CAN I DRILL AND TAP IT AND GO WITH A LARGER PLUG?I JUST STARTED RIDING IT THIS SUMMER AND NOW I DONT WANT TO TEAR IT BACK DOWN AGAIN,PLEASE HELP!DO I NEED TO PULL THE HEAD AND CAN I DO IT WITH THE ENGINE STILL ON THE BIKE?
- Thank you received: 2098
20 Apr 2010 12:17 #361967
by Patton
Replied by Patton on topic CROSS THREADED PLUG
Just use a reverse tap that starts from the deep end where the threads should still be good.
No disassembly required.
- scubarod
20 Apr 2010 12:23 #361968
by scubarod
Replied by scubarod on topic CROSS THREADED PLUG
I BELEIVE I HAVE GONE TO DEEP AND THE PLUG WILL NOT SEAT
- jeffasaki
- Thank you received: 44
20 Apr 2010 12:29 #361969
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Replied by jeffasaki on topic CROSS THREADED PLUG
I had the same problem on a alumiun car head.I brought the bad cylinde up to almost TDC on compression stroke,filled the chamber with grease retapped to a larger plug size and finished turnibg the crank to finisf compression stroke,pushed out all the cuttings and most of the grease,a helicoil my give you problems becauese the different metals have different rates of expansion.Will smoke on startup while the grease burns off.
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
20 Apr 2010 12:33 #361970
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic CROSS THREADED PLUG
I have to second what Patton said about the reverse tap. I've fixed 2 heads this way and it works great. Make sure you fully understand how this tool works before you dismiss it.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- BSKZ650
- Thank you received: 14
20 Apr 2010 12:44 #361972
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic CROSS THREADED PLUG
Heli coils will not work for the spark plugs, the ydoo however make a timesert, which is a threaded sleeve , you drill it out larger and tap it, screw in the sleeve, with locktite, you now have a flat surface for the plug to seal on, and back to a standard plug.
grease and a shop vac work well to keep shavings out of the cyl, shop vac, I have adapted via duct tape a small hose to get down close to where the shavings are and you can run it down inside the cyl to make sure everything is out
- scubarod
20 Apr 2010 13:24 #361975
by scubarod
CAN YOU TELL ME WHERE I WOULD FIND THE TIME CERTS?
- scubarod
20 Apr 2010 13:25 #361976
by scubarod
WILL I BE ABLE TO GET THE CORRECT PLUG RATINGS BY GOING TO A LARGER PLUG SIZE?
- scubarod
20 Apr 2010 13:46 #361984
by scubarod
DO YOU KNOW WHAT SIZE I NEED ?AND HOW BAD A THREAD WILL THIS FIX I DO NOT THINK THE THREADS ARE STRIPPED BUT THEY ARE CROSSED ALMOST ALL THE WAY DOWN AND I DID REMOVE A FEW PCS OF THREAD
- scubarod
20 Apr 2010 15:04 #361999
by scubarod
i like your way and i am trying to figure out now what size time cert i will need to complete this task,thanks for the suggestion!
- Motor Head
- Thank you received: 391
20 Apr 2010 17:54 - 20 Apr 2010 17:55 #362032
by Motor Head
Replied by Motor Head on topic CROSS THREADED PLUG
Both K&D Tools and Heli-Coil make solid inserts and the self drilling tap to cut the threads, I put 2 in my KZ1000.
I have a K&D set from the 70's well used and always does a great job.
Last edit: 20 Apr 2010 17:55 by Motor Head. Reason: spelling
- BSKZ650
21 Apr 2010 09:15 #362137
by BSKZ650
find a NAPA store or some GOOD parts house, the nimrods at autozone and the likes have no clue, the good places with people who know parts will be able to order it for you
