Bike acting sluggish
- paulstanely45
- 1977 KZ650-B
20 Apr 2010 11:26 #361947
by paulstanely45
1977 KZ650-B
Replied by paulstanely45 on topic Bike acting sluggish
Well I have rebuilt my carbs this year, so the float valve assemblies are new.
I had noticed that my oil level had gone up though, I figured it was just that the oil had expanded because the bike was hot, and I had brought it to the marker during the oil change while the bike and oil were at room temperature.
How would the gas get into my oil though?
It seemed like the problem happened all of a sudden. I suppose the proper step to take would be draining the oil and making sure the floats arent leaking?
1977 KZ650-B
- Thank you received: 2098
20 Apr 2010 11:55 - 20 Apr 2010 11:57 #361962
by Patton
Replied by Patton on topic Bike acting sluggish
paulstanely45 wrote:
Where too much fuel enters the float bowl (for whatever reason) and fails to escape though the overflow (for whatever reason), fuel can rise up into the carb throat and make its way to the combustion chamber where it flushes down around the piston into the crankcase.
Would also expect to see fuel dripping from the pod.
... How would the gas get into my oil though?....
Last edit: 20 Apr 2010 11:57 by Patton.
- paulstanely45
- 1977 KZ650-B
20 Apr 2010 21:59 #362071
by paulstanely45
1977 KZ650-B
Well, I suppose Ill do an oil change and check my carbs.
Not sure how that would make where the headers connect to my exhaust kinda gooey though. I suppose Ill keep pissing around with it until I managed to get it to run right. I wish I knew if it was a compression problem.
1977 KZ650-B
21 Apr 2010 03:56 - 21 Apr 2010 04:04 #362087
by Patton
Fuel intrusion into crankcase does not result from low compression.
Excessive richness in fuel mixture results in extra goo being discharged through exhaust port, which escapes past poor seal (for whatever reason) at copper gasket area.
Last edit: 21 Apr 2010 04:04 by Patton.
