Bike acting sluggish
- paulstanely45
- 1977 KZ650-B
This morning I start up my bike and I noticed the exhaust sounded kinda funny. I also noticed the bike was kind of sluggish and less responsive.
I pull the bike into my shop and look at the carbs, now that I think about it I didn't look inside the passage, but the jets appeared to be spotless, along with everything else. I am using a glass fuel filter, and it looks pretty clean. I had rebuilt these carbs two months ago as well. I do have a small rust seem in my gas tank, but the fuel filter appears to be perfectly clean as I said.
I had noticed when I twisted the throttle that some black smoke shot out the front of the bike (the exhaust was leaking right at the exhaust collar). I had just been using permatex copper silicone in place of an actual gasket. I do have some crush type copper exhaust gaskets now though, I just haven't installed them.
Would an exhaust leak cause a loss in power and kind of chuggish/sluggish engine behavior at low rpms? It would explain why the exhaust sounds kinda funny.
The bike in question is a 1977 KZ650B1
It has pod filters, 117.5 main jets, and 17.5 pilots. I am using an electronic ignition and dyna coils.
My exhaust has 1 and 4 go out through the left pipe, then 2 and 3 out the right pipe.
1977 KZ650-B
- Thank you received: 2098
Would install brand new spark plugs (per factory specs), and test run.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
You bet!
It can also damage the exhaust valves in your engine.
With pod filters, your should have a 1 size increase on your Pilot Jets, and roughly a 4 size increase on the Main Jets, with the needle clips being moved down one notch (raising needle) to make midrange richer.
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- sft1662
I was about 100miles from home on my first long ride yesterday and suddenly my exhaust started sounding weird (deeper?) and when I would get on the throttle not much would happen... after a while it would go back to normal... pretty sure I was dropping cylinders! no fun! (I'll start my own thread to solve that issue )
good luck!
EDIT: if you are on 3 cylinders and a choke circuit is clogged on one of them it will take FOREVER to warm up, one cylinder may not really warm up at all even after taking it off choke. And pulling from a stop will be very difficult... been there done that.
1978 KZ650 B2A
- paulstanely45
- 1977 KZ650-B
My coils are brand new, and my timing is bang on (using the dyna electronic ignition)
When installing the copper gaskets, do I need to use any silicon with them?
1977 KZ650-B
- patmann
- Thank you received: 6
NO. That copper stuff( imo ) tends to cause more problems than it fixes in exhaust systems. Make sure you clean all the old stuff out too. Otherwise you will have leaks with you new copper gaskets. Do it right the first time.
Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
- paulstanely45
- 1977 KZ650-B
Im not sure if I am just imagining it, but it kind of sounds like it did when I would leave the choke on. A bit of a deeper sound than it usually has.
I bought some seafom and put that into the gas tank, let it run for a bit, but havent done much riding.
Any other suggestions?
Once again, I took apart the carbs, but like an idiot I didnt look in the passages, I just looked at the jets. I will be going down a jet size though pretty soon, so Ill be sure to make sure that all the passages are clear.
The big problem I notice is that it seems kinda sluggish when I am in first and getting going (i.e. letting the clutch out to get moving).
1977 KZ650-B
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- paulstanely45
- 1977 KZ650-B
1977 KZ650-B
- timebomb33
- paulstanely45
- 1977 KZ650-B
cylinders 1 and 4 route out to the muffler on the right side of the bike (the side my right leg would be on if I were sitting on it). Cylinders 2 and 3 obviously run out the the other side.
The muffler that 2 and 3 run to was puffing out white smoke this morning, and yesterday. After I ran the bike for a bit it appears to stop. I noticed the other day when investigating, that cylinder 2's spark plug looked pretty black and wet, oily if you will. Where the pipes for 2 and 3 meet the muffler seemed kinda wet and oily too.
Im getting the impression I have some worn rings or a valve problem. Any recommendations to help narrow down the issue?
1977 KZ650-B
- timebomb33
