Kz1000 motor into a zephyr 550??
- rnuse
- Balls to the walls, sideways all the time
06 Apr 2010 09:15 #358724
by rnuse
1982 kz750 ltd
Drag bars, 4into1 V&H with no baffle.
1991 zephyr 550
about to give up on her.
Kz1000 motor into a zephyr 550?? was created by rnuse
Have an opportunity to buy a motor with carbs and exhaust. Will it fit without too much modification? Anyone have any experience doing this? I know the 550 is the same as the old 80's kz550. The 1000 is a 77 and zephyr is a 91.
1982 kz750 ltd
1991 zephyr 550
- BSKZ650
- Thank you received: 14
06 Apr 2010 10:18 #358733
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Kz1000 motor into a zephyr 550??
anything can be made to fit, but is it really worth it??
Step away from the tools!!!!:woohoo:
- zed1015
- Thank you received: 1556
06 Apr 2010 10:41 #358744
by zed1015
Replied by zed1015 on topic Kz1000 motor into a zephyr 550??
This would be a very VERY tight fit if at all possible . 550 motor is even smaller than the 650 and the 650/1000 conversion is a tight job.
- loudhvx
- Thank you received: 1616
06 Apr 2010 10:51 #358747
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Kz1000 motor into a zephyr 550??
It is possible to shoehorn a Gsxr 750 motor into a Zephyr 550 frame, but there is no room at all anywhere and that is with a lot of massaging. I belive that motor is only a little bigger than the Zr550 motor. I don't think you could put a KZ 650/750 motor into a zephyr 550 frame without a lot of trouble. A kz1000 motor would probably require the frame to be cut in half and extended etc.
1981 KZ550 D1 gpz.
Other links.
- rnuse
07 Apr 2010 07:35 #358954
by rnuse
1982 kz750 ltd
1991 zephyr 550
Replied by rnuse on topic Kz1000 motor into a zephyr 550??
The zephyr has been a pain to get right. Still won't rev past 6k. The 1000 motor is rebuilt and ready to run. Seemed fun but I'm definately not going through the work to stretch the frame. I really wanted to know if the mounts were the same. And that was all I needed.
It sure would be a fun bike.
1982 kz750 ltd
1991 zephyr 550
- otakar
07 Apr 2010 07:45 #358956
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Kz1000 motor into a zephyr 550??
My brother has a Zephyr 750 and you couldn't put a 1000 motor into it. The frame is completely different from the older bikes when people put 1000 motors into 650 frames. Mater of fact the frame is so tight that Kawasaki had to come up with a customized carburetor arrangement just so they could put carburetors on the Zephyr 750. If you have a good torch you can do it. Without a torch , a saw and a welder NO.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
