Adjustable cam sprocket replacement with stock
- 6leafclover
1979 KZ1000-E1/ST
Madison, IN
- PLUMMEN
- Thank you received: 104
- 6leafclover
1979 KZ1000-E1/ST
Madison, IN
- larrycavan
- Visitor
Andrews called for 106 centers. However, degreeing the cams is not to be taken lightly. If you're not comfortable with doing it, either get the motor in the hands of someone who is or go with stock sprockets.
Make sure you get the correct sprockets.
There are 30 and 32 tooth sprockets. The 32's are for the MKII motors [16pin crank].
- 6leafclover
1979 KZ1000-E1/ST
Madison, IN
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
im pretty sure they would have to be 1x or 2x i dont believe the motor is bored (will measure when i get the head the rest of the way off) and it always ran very very strong with stock carbs and even stock jetting so i wouldent think that the cams could be too radical. up untill now i thought the entire motor was stock, boy was i happy to find a set of andrews in there, too bad the spocket got thrashed. I will just bolt on the stock ones. now do i have to use both stock ones or can i leave the one adjustable one that is good and just change the chewed one?
You can mix and match between stock and adjustable. The cams will be marked at the end. Just pop off the rubber endcap on the head and you should be able to read it.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- 6leafclover
1979 KZ1000-E1/ST
Madison, IN
- keith1
- Thank you received: 2
and empty out the bits.....i run andrews 2x cams on stock sprockets as i am not comfortable with degreeing....degreeing can be a pain for what?3-5 horse max?.....good luck and get the wallet out...
here is what my tensioner looked like....
- Old Man Rock
- Thank you received: 225
kzrider.com/index.php?option=com_docman&...d&gid=451&Itemid=108
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- larrycavan
- Visitor
I'd put both on stock sprockets or degree both. Make sure you spray the bolts and cam bolt holes out with brake cleaner and use red locktite on the bolts.
I have a 1075 with 2x's, ported head and 29's in the shop right now with the cams on stock sprockets. It runs perfect!
- keith1
that combo sounds familiar....hhmmmmmm....:laugh:
