- Thank you received: 337
Liquid gasket on valve cover?
- bountyhunter
Not necessarily. There is a cam chain tensioner attached to the cover on mine that bears down on the chain so dropping it .030" downward into the chain might not be good.Just went out and did some carefull measurements. Seems there is at least 1/16th inch of clearance even if no gasket or sealant is used, so I'm okay there. )
- Motor Head
- Thank you received: 391
Still like the "RUBBERIZED" CORK. This is what the best gasket maker in the USA, FELPRO, uses for many valve covers and oil pans. Just don't over tighten it.
- T_Dub
- Thank you received: 25
I'm not necessarily going to go with sealant only myself, but after reading how Ford, Chrysler, GM and others are now going the sealant route only (except of course head gaskets) on many of their engines, and having some past experience with it myself, I'm not fully convenced that paper gaskets are the only way to go. I'll probably try it and if it doesn't work out...well, then I will have learned!
I think they specially design their stuff to work better with liquid gasket. The probably have channels in their parts so that it doesn't squeeze into the engine and whatnot.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- Thank you received: 2829
- RonKZ650
- Thank you received: 240
- polkat
- Thank you received: 1
It would be spread on thinly with a finger, not gobbed on, and I have found that removing old sealers like silicon for example is a pretty simple process.
Again, this is just a thought, but seems a lot more convenient then sending off for a gasket whenever needed and then waiting around to get it.
- PLUMMEN
- Thank you received: 104
then you can pull the valve cover off once then just wipe down bottem side of gasket really good and throw a little sealer on there
- TeK9iNe
- What did you do!?!
It doesnt solidify like regular gasket maker, thus no clogs anywhere if a little oozes into the engine.
I doesnt cause any detrimental contamination of the oil either...
It can be used everywhere, even in the presence of gasoline! It wont leak/melt or nothing like the other gasket products.
Removal is super easy. Just gently pry the parts apart (very little effort), then use a rag and some break cleaner to remove the old gasket! :woohoo:
Its the #&%$! I'm tellin ya! :laugh: :laugh: :laugh:
1194 for base... REAL gasket for head...
+ I hate the look of pieces of paper sanwiched all over an engine, you can just wipe excess liquid gasket away!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
