- Thank you received: 1
Liquid gasket on valve cover?
- polkat
I need to replace the valve cover on my 750-4, and was thinking of using just a liquid gasket instead of using the standard paper gasket (and not once again sending $20 or more, then waiting around a few weeks for that expensive piece of paper).
If it works for Ford and GM, would it work for me?
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Proper copper for Head gasket.
Threebond 1194 or 1104 "Yama-Bond" for Base Gasket.
Permatex #2 Liquid gasket - for everywhere else!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Motor Head
- Thank you received: 391
But back to you're question, it is true that many valve covers and really the rest of the motors are put together with silicone seal. But so far I've yet to see a head gasket replacement made from liquid, but it may not be far off.
- bountyhunter
- Thank you received: 337
- polkat
Where have you found it?
- JR
- Thank you received: 448
I used that Permatex #2 stuff last year for new carb boots and was thinking for valve cover. What's it like to get a valve cover off and to remove the stuff ?
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- TeK9iNe
The permatex #2 (white tube) doesnt harden up nearly as much as the others, and is quite easy to remove from any surface.
LINK LINK LINK
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
I've been looking for the Threebond 1194 for a while now. I live in a rural area of northern California, and can't find any local store that carries it.
You can order the 1194 from HERE @ Z1ENTERPRISES
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- PLUMMEN
- Thank you received: 104
areas with a wide contact area work good with sealer,valve cover is kinda thin and most of it would end up in cam bearings or oil gallerys i think
- timebomb33
I THINK MY POWERBAND BROKE
- polkat
