valve clearance check for a dum@@s with no book
22 Mar 2010 08:10 #355378 by gottmoore
kz1000p 95. How hard is this REALLY? I have basic tools and some aptitude.
Just changed the wires, plugs and oil on a reasonbly new buy. I figure this is a good a time as any, and Im getting a little cam chain noise and mild tap (valves?) on new oil.
22 Mar 2010 08:13 #355379 by timebomb33
Replied by timebomb33 on topic valve clearance check for a dum@@s with no book
i usally go .004" on the intakes ,.006" on the exhaust for my stuff.
I THINK MY POWERBAND BROKE
22 Mar 2010 08:15 #355380 by Nebr_Rex
get the book
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
22 Mar 2010 08:18 #355381 by timebomb33
and get the right shim tool it will make your life easier.
22 Mar 2010 11:14 #355425 by bountyhunter
Replied by bountyhunter on topic valve clearance check for a dum@@s with no book
The spec is .002" - .004" for both intake and exhaust on the 750 twins. That's unusual, typically the exhaust valve spec is a shade wider because it gets hotter. I think .003-.004" intake and .005-.006" exhaust is safe.
22 Mar 2010 12:40 #355448 by gottmoore
Replied by gottmoore on topic valve clearance check for a dum@@s with no book
thx guys.
What I'm looking for is about how long this will take ( an hour or a weekend), and if I gotta buy some parts BEFORE I start tearing apart. I hate to be without the bike, especialy if I can avoid it.
@ rex-thx for the especially brilliant reply to my question:laugh: I did deserve it, didn't i-
The manual doesn't always have insight that only comes from experience. These forums are the best at saving time/money if your read enough, or in the case write enough!
  • DoubleDub
  • Visitor
22 Mar 2010 13:59 #355460 by DoubleDub
Replied by DoubleDub on topic valve clearance check for a dum@@s with no book
Well...it will take longer the first time. And depending on whether you have a shim removal tool or not, it may involved removing the cam shaft retainers to change shims. You will definitely need shims...but it's almost impossible to determine what you'll need until you measure clearances and find out what sizes are in the bike.
Best bet (cheapest) is to measure clearances, find out what sizes you have and then do the whole process again when you get the needed sizes. Otherwise Z1E sells a package of shims for ~$100 that should cover just about any necessary size.
22 Mar 2010 15:45 #355478 by kilgore
With an'87 KZ1000P, I feel your pain,lol. The Clymer Manual(got it from library!) for '81 - '02 specs clearances @ .05 - .15 mm. for both intake and exhaust. Go figure!
Here's my experience, limited as it is. Ya don't know if you're out of spec untill ya take off the valve cover and measure. (guys on here say it's good to here a little valve knocking.). If you're out of range, ya gotta see the size of the shim in the bucket. I bought the removal tool from Z1E - Works fine. I was able to swap out two shims to get everything within spec, but I got lucky. The thing is, you don't know till you measure clearance, then you have to figure out what size shims you need to buy or swap out. If you're as anxious to ride as I am, this can be excruciating because you have to buy the tool to see what size the shims are, then order/buy the shims you need. Sorry, is this confusing enough for you, lol?
Don't forget to get a new gasket, and I'm kicking myself for not buying the cam end caps as well.
Hope this helps and good luck!
22 Mar 2010 16:56 #355489 by timebomb33
i can do a shim job on any of my shim over bucket motors in about an hour my shim under motors take about an 1 1/2 to 2 hours if i have to change any. so basicly what i'mtrying to get across is they aren't that hard to do. so take your time and it will go well. and if you have any problems you know who to get a hold off these guy's on here know there stuff even OMR and sometimes Patton.
22 Mar 2010 17:46 #355497 by gnfreak
i was able to move a couple of shims as well and then the shop traded my old shims for diffrent ones even up.
Normal, IL
1980 KZ1000-G1 Classic - Sold
22 Mar 2010 20:40 #355531 by bountyhunter
You're lucky, the Kawi dealers around here won't swap shims they just want to sell them to you for about $15 each.
22 Mar 2010 20:42 #355532 by bountyhunter
gottmoore wrote:
thx guys.
At minimum you will need a valve cover gasket, a shim tool and shims. You also need a low range torque wrench to retorque the camshaft cap bolts if ytou have to take them loose because they strip easily.
