- Thank you received: 109
z1 pops out of gear
- mark1122
- Keep twisting it
21 Mar 2010 09:07 #355154
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic z1 pops out of gear
gsledder2 wrote:
I think u could get at them from the bottom, if u had too.
Also the cogs on the gears sides can get worn.They hold the gears together by friction. Racers have these cogs cut on an angle so the lock themselves , by siding together under load , rather than slide apart.
Hopefully , the above advice will do the trick. Another known issue is the shift forks. they can get bent, and not hold the gears together well under light loads.tx much been looking every where for info just pops at low rpms
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
- Thank you received: 104
21 Mar 2010 12:01 #355193
by PLUMMEN
Replied by PLUMMEN on topic z1 pops out of gear
its the z1 gods getting back at you for putting the motor in a 4 wheeler! :laugh:
- gsledder2
21 Mar 2010 12:55 #355200
by gsledder2
Replied by gsledder2 on topic z1 pops out of gear
ok checked the paw spring it in tolence and yes think somebody tell to stay off of it to fast runs about 120 15 front spocket 40 on the back and 20 inch tires its a fun ride have had the motor just sitting there had to do something with it blew the stock motor on the quad tx to oil pump
