z1 pops out of gear
- gsledder2
21 Mar 2010 05:51 #355109
by gsledder2
z1 pops out of gear was created by gsledder2
new here and not a very good typer sorry.ok had the motor sitting around for 13yrs so put in a quad rides nice but pops out of 3 at low rpm.so this year i put new clutch springs heavy duty and now it pops out of 2 and stays in 3 do a little cluch adjustment then stays in 2 and pops in 3 again could it be oil 10x30 royle purple or internal
- otakar
21 Mar 2010 06:14 #355112
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic z1 pops out of gear
Oil should not have anything to do with it. If it happens at Idle or slow speeds, it sounds like an adjustment issue. Especially if you never had the problem before. It may also be that the gears are not fully engaging. If the bike sat for that long I would start out with some very light Hi detergent oil or just add some "marvel Mystery Oil"@ to the oil or Rislone@ to see if you can clean up the inside the tranny. I would also check very carefully your clutch adjustment. These transmissions did sometimes pop out of gear, but under high power output situations when the engines were heavily modified. Not under regular street use.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Old Man Rock
- Thank you received: 225
21 Mar 2010 06:24 - 21 Mar 2010 06:26 #355116
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic z1 pops out of gear
Before getting all wound up on the internals, check the Pawl Spring, De-tent Arm Spring and Shift Pawls are in specifications/tolerances and adjusted correctly for operations first...
Most likely just the Pawl spring has broken or is weak... These can be obtained for ~ $6 from Z1...
It can be many things as depicted in the RED box.... Hopefully it will be something minor that can be repaired externally otherwise you'll have to split the cases to get into the transmission....
Hope it works out for you...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 21 Mar 2010 06:26 by Old Man Rock.
- otakar
21 Mar 2010 06:28 #355117
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Hay Dave, don't you ever sleep? :laugh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- gsledder2
21 Mar 2010 06:32 #355118
by gsledder2
Replied by gsledder2 on topic z1 pops out of gear
tx much been looking every where for info just pops at low rpms
- Old Man Rock
21 Mar 2010 06:41 #355121
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
"Hay Dave, don't you ever sleep?"...
Unfortunately no :blush: ... ARMY clock still in gear even after 23 years... Basically same as you mi amigo! :laugh:
Besides, have to get up early to beat you to the replies... :laugh: :laugh: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
21 Mar 2010 07:06 #355128
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
No eBay APP ID and/or Cert ID defined in Kunena configurationI would highly recommend that if you do not already have one, that you obtain a Kawasaki service annual for the bike. They are worth their own weight in blood, sweat and tears.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Old Man Rock
21 Mar 2010 07:09 #355129
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Bid for 24 days... Screw that, follow the link and buy now @ $66....
I have that same exact manual... No other way to go....
Sweet Otto....
OMR
Sweet Otto....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- gsledder2
21 Mar 2010 07:42 #355134
by gsledder2
tx for the info i have a manual on order from local kaw shop should be here thi week
- gsledder2
21 Mar 2010 07:46 #355136
by gsledder2
0ne quick ? running about 5 to 8 pounds oil pressure at idle is that about right
- otakar
21 Mar 2010 07:49 #355137
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Make sure that it is an OEM Kawasaki manual, and not a Clymer or Chiltons. Those are junk. Kawasaki part #99997-700-07 do not buy any substitute for that book.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Old Man Rock
21 Mar 2010 08:13 #355139
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
