smokin like hell
- djcamp10
1. its white smoke and lots of it
2. it doesnt go away even after 20-30 min of runnin and the amount of smoke greatly increase with increased throttle
3. when i pulled the exhaust pipe only one pipe smelled of fuel
4. it is a 77 kz650 b1
after hearing that my first guess is i could have a ring out but this is truly an uneducated guess at best. any ideas am i on the right path? any suggestions? must resolve said issue quickly i leave for iraq in 6 month and want to ride like hell till then
1977 Kz650 B1
- djcamp10
- keith1
- Thank you received: 2
- 550A2
- keep the shiny side up
- Thank you received: 1
Hope you done have a bad ring, if you did it would run like shit.
What does the smoke smell like?
If it is oil smoke you prolly have oil leaking past your valve seals from sitting all winter.....
someone else will chime in im sure but thats my thoughts on it.
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
- Thank you received: 2829
- baldy110
- Thank you received: 512
- Thank you received: 2098
- bountyhunter
- Thank you received: 337
sounds like blow by the ringswell it's once again this time of year where my wonderful kz comes forth with another problem and i write ya'll veteran kz owners . so here it is at the end of last season she started to smoke like hell. so lets cut out some of the question post that are sure to follow.
- djcamp10
1977 Kz650 B1
wow rough crowd last night lol but it is what it is i enjoy it i'm the one thats got to ride it but any who the exhaust smells like fuel. valve seals should be in pretty good shape as far as i know they were replaced 3 years ago. how do i go about narrowing this down to which wonderful obscure part to replace (so far i got could be the seals, blow past the rings, and seat and handle bars) note i've eliminated the seats and handle bars by disconnecting them from the flux capacitor
If not already done, would ---
Confirm combustion in all four cylinders by spraying water mist onto exhaust header from running engine. Should immediately sizzle and burn off.
Assure proper fuel levels in float bowls via clear tube test.
Determine whether excessive oil vapor is escaping from crankcase breather vent while engine is running.
Perform compression test.
Repeat compression test on each cylinder after adding a teaspoon of oil into combustion chamber.
Perform leakdown test. Including whether compressed air is escaping from the crankcase breather vent, which indicates blow-by past rings/piston into crankcase.
Assure air filters are clean and not over-oiled or otherwise blocked. Reportedly, some cheaper units may partially obstruct the smaller hole at entrance to pilot circuit air intake passage.
Sniff-test crankcase oil and examine its physical condition to determine whether it has been contaminated with fuel. This will cause exhaust smoking. If in doubt, change both oil and filter.
- larrycavan
- Visitor
IF you were close by, I'd help you fix it for free! Keep your head down over there! Be safe and come back home!
- BSKZ650
- Thank you received: 14
wet and oily, rings.
bet the 1.21 gigawatts did it:woohoo:
77 ltd1000, current rider
76 kz900, just waiting
