- Thank you received: 225
Sanding valve shims?
- Old Man Rock
"To be exact, they are $4.62 each at Z1E."... I was including shipping... :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2098
Depending on the actual shim sizes at hand, perhaps one of the >.10mm site shims could exchange with an .04mm shim site.
But at most, seems only two shims would be needed.
- polkat
- Thank you received: 1
It was my understanding that .05mm is too small as well. Someone here said that .05 is okay, but the book says .08 minimum. I didn't know Z1 had them. I'll check with him.
FSM for large fours from '73Z1~'79KZ1000 says .05mm~.10mm valve clearance. (28mm over-bucket shim)
But apparently factory spec for KZ750 clearance is larger @ .08mm~.18mm (as cited in another forum), for 13mm under-bucket shim. Same as KZ650.
Would abide by the FSM for KZ750.
Depending on the existing shim sizes at hand, may be able to swap shim sites to gain required clearance.
- polkat
Still, I am very poor and trying to get this engine running as best I can. I got to thinking that the buckets support one whole side of the shim, as opposed to the little valve stem on the other side. If only the bucket side of the shim were worked down, as flat as possible, would the removal of the nitrate on that side still be a problem?
Yes, I am trying to get the engine running as cheaply as possible, and I realize how stupid that might sound. After all, $5 for a shim might seem trivial(and it is), but $25 or more for several is hard for me when it's a struggle just to get food each day. All the responses are quite appreciated!
- BSKZ650
- Thank you received: 14
they are not nitrated they are case hardend, total different process.
the purpose for them being harder is to resist wear on both sides, if you weaken any part of the shim, it IS going to FAIL.
since money is tight, post the sizes of the shims you need, maybe one of us here can swap you shims then you are not anything but some postage, just make sure to send the shims back to whoever you strike a deal with
77 ltd1000, current rider
76 kz900, just waiting
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- trianglelaguna
- Thank you received: 235
i stole the grips off of amy's nieces big wheel and used a sharpie to color to match my bike...saved me six dollars each...bought 12 one dollar scratch offs and won a free ticket...my ass is gonna be rich ,when i get back to quickie mart tonight......
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- polkat
Anyone?
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
