- Thank you received: 1
Sanding valve shims?
- polkat
09 Mar 2010 18:23 #352320
by polkat
Sanding valve shims? was created by polkat
KZ750H3.
I know that the book says not to try grinding valve shims, as they may crack, etc. However, I wonder if you could safely use some fine grit paper with oil and a prefectly flat surface to take maybe .05mm off? Anyone ever try this?
- otakar
09 Mar 2010 18:26 #352322
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Sanding valve shims?
These shims are Nitited if you remove anything you will remove the hardened surface and they will cup and destroy your cam.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- T_Dub
- Thank you received: 25
09 Mar 2010 18:30 #352323
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic Sanding valve shims?
If you can Nitride them once you're done then fill your boots.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- otakar
09 Mar 2010 18:38 #352325
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
It is even worse with the 13mm under bucket shims because they are sitting on a 6mm stem instead being fully supported and will have a tendency to shatter.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- polkat
09 Mar 2010 18:54 #352329
by polkat
Replied by polkat on topic Sanding valve shims?
Is nitride an expensive process? I can't afford a new selection just to get two or three shims, and I can't find the right size used ones.
- otakar
09 Mar 2010 18:58 #352330
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
When i get my rifle barrels done it costs me about $60 a unit. It is the process not the price of the liquid Nitrogen
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- keith1
09 Mar 2010 19:08 #352332
by keith1
Replied by keith1 on topic Sanding valve shims?
i m not trying to be a tool, but you cant do a rebuild looking to cut corners on every aspect....you can maybe cut a corner here or there, but the bottom line is that no matter what CC you ride, you are going to have to drop some cash.....everyone has financial constraints and they vary from member to member....trying to take the cheap route on every aspect is a recipe for disaster....the economy sucks right now and jobs are scarce....maybe putting some stuff off for a while might be wise choice.....no malice or ill will intended, just looking at this from a different angle.....
- otakar
09 Mar 2010 19:10 #352333
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
New shims are only $5 each.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Old Man Rock
- Thank you received: 225
09 Mar 2010 19:13 #352335
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Sanding valve shims?
Oh KZ God why...
I mean truly, shims are only $6 each... I'm with Keith and others on this one, no way would I go this route no matter what you do to them to harden them up... Just not worth losing an engine over...
Same time, your bike, do what you wish...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
09 Mar 2010 19:21 #352341
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
To be exact, they are $4.62 each at Z1E.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- nads.com
- Thank you received: 20
09 Mar 2010 19:23 - 09 Mar 2010 19:25 #352343
by nads.com
Replied by nads.com on topic Sanding valve shims?
Sanding won't work I used a belt sander and nada. I wore half a grinding wheel off and nada. Did I buy a new one? HECK no. After 2 hours i got almost a tho off! And it looked like crap! Course i used it, you kidding me? Course it worked! But this is mee and i dont even dot my eyes anymore! It's more in the way people look at you, i mean u don't have to tell them why theres a hole in your head. OH yeah, burned my fingers too! A whole lotta fun! FACT of life: Service dept. employees get REAL crabby when u ask for a thin shim. So bring two to smooth things over. Bring em the lucky one! :laugh:
Last edit: 09 Mar 2010 19:25 by nads.com.
- Thank you received: 2098
09 Mar 2010 19:30 #352344
by Patton
Replied by Patton on topic Sanding valve shims?
FSM should instruct about "tipping" the valve stem, which adds clearance by "shortening" length of the valve stem.
This would be most useful in cases where the thinnest shim isn't thin enough to provide the needed clearance.
