- Thank you received: 14
Weird valve clearances?
- BSKZ650
Well, here's what is also weird. I understand shims were made in .05mm increments, but when I measured the shims before I reinstalled them, I got some weird numbers like 2.54mm (three like that), one 2.59mm shim, a 2.56mm, a 2.64mm, and two 2.48mm's. My measuring technique is accurate (a good quality millimeter caliper). They look good (not much visable wear) but that doesn't sound like original factory sizes to me. If I need them, where can I get individual shims?
Also, I may not have always put the same side of the shim against the valve stem when I reinstalled. Would that make a difference (doesn't seem so)?
Lastly, I have found several shim buckets that spin fine when installed, but are quite difficult to remove from the head. Is there a trick to this? Thanks!
I have some used shims that do not measure as they are marked, and dont look to be worn, I suspect that there were some tollerances during the mfg process.
77 ltd1000, current rider
76 kz900, just waiting
- Thank you received: 2098
Usually a good idea to install the shim with number side down against the bucket and away from the cam lobe, whereby the number won't be worn away by the cam.
Good Luck!
- larrycavan
- Visitor
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- polkat
Any suggestions for a bucket that won't come out? I pulled the buckets off again last night and exhaust one's bucket is stuck hard.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Try your best not to mark it up.
A real strong magnet might work best.
GL
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- otakar
Liquid wrench, or the like, to remove the bucket.
GL
Yes a strong magnet works the best.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- polkat
I'm afraid I might have to drill a little hole in the top-near the side so I won't hurt the retainer, then grab it with a screw. Of course, I'll have to replace the bucket but I have no idea where I might find a single one. Any other ideas?
- polkat
Then you can knock the bolt sideways and it will pop off without damaging the bucket. The remaining glue scrapes and cleans off easily with acetone.
Now, I measured the bucket diameter....and found it to be about .05mm wider then the rest. What? How can that happen, and why wasn't it a problem when someone did the last rebuild?
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- nads.com
That's a good point. You have to zero them over and over and you have to squeeze them together like you gotta pair. Try measuring valve stem spec's end to end without closing the caliper tightly. BAM! Your late for dinner.Also, cheap digital calipers are not accurate. That leads to inaccurate readings.
- BSKZ650
