- Thank you received: 1
Weird valve clearances?
- polkat
Intake One .05mm / Two .05mm / Three .10mm / Four .04mm
Exhaust One .05mm / Two .05mm / Three .08mm / Four .04mm
[These are the feeler gauge sizes that would fit without forcing]
These seem a little tight to me as I understand that minimum clearance should be .08mm, but do you guys see a problem? And if so, what can I do about it?
Thanks!
- Thank you received: 2098
While changing valve seals, I did a valve seat and face cleanup with just mild lapping, After assembling the head (putting same parts where they were originally of course) I got these clearances.......
Thanks!
If specs @ .05~.10mm clearance, would go next thinner shim at the two .04mm sites to get .09mm clearances.
Not critical imo but won't hurt to go next thinner shim at the four .05mm sites to get .10mm clearances.
- polkat
Also, I may not have always put the same side of the shim against the valve stem when I reinstalled. Would that make a difference (doesn't seem so)?
Lastly, I have found several shim buckets that spin fine when installed, but are quite difficult to remove from the head. Is there a trick to this? Thanks!
Thanks!
Just a friendly reminder that it's usually very helpful to those responding if a poster will please include make and model within signature. Saves a lot of guessing and enhances accuracy of reponses. [See following.]
And may be modified whenever desired.
