Pics of new pistons
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- fordtruck
- Thank you received: 6
I'm sticking with stock cams for now. Might go with Web 118's later on. The cam chain and all the rollers ate up my money I had for cams!
'77 KZ1000-MTC 1075 kit. Stage 1 port
- School Teacher
Joe charges $125 to punch the 4 holes. Unfortunately he just had to raise his prices. Not to long ago he was charging only $100. I send all of my stuff to him, because here in the Chicago area about the cheapest you will find is $60 a hole. The last ones he did for me were my GPz1150.
Are these 83-84gpz pistons? MTC? what size pins? are they in an actual gpz engine or a kz bottom with the gpz top?
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
- School Teacher
Yes, Joe Hooper is the owner of Pitstop Performance Orlando FL. The coating I do and it is a Ceramic crown with Molly skirt. The Ceramic is both a tremendous heat barrier and also prevents anything from sticking to the crowns. As you run your bike, carbon sticks to the crowns and unbalances the pistons, and also causes detonation and pre-ignition.. This prevents that from happening. Also it prevents oil from burning onto the underside of the dome because it lowers the temperature. The molly tightens up the bore and lowers skirt ware.
Joe Hooper
Pit Stop Performance
3213 Paisley Circle
Orlando, Florida 32817
joehooper@cfl.rr.com
407-679-9116
the ceramic coating is that a gunkote product or what? and the molly how is it done do tell!? thanks
1980 kz1000G1
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Jack
- Thank you received: 7
Those are GPZ domes with KZ skirts and in a custom 1150 size (66.5mm). 17mm pins KZ tranny with 84 GPz top. The ceramic is a dry applied product that is baked on at 650*f for 6 hours. The molly is applied while the piston is at 300*f They are German products.
Had piston skirts done in past by Swain in NY.Is the moly a self applied product or did you send them out for coating ?
300F* I can do, 650F* will be a little tougher...also my wife wants to know the moly smells like while baking ,thinking back to Gunkote in the oven projects.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- larrycavan
- Visitor
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
