- Thank you received: 225
1979 KZ1000 cylinder PSI
- Old Man Rock
28 Feb 2010 17:36 - 28 Feb 2010 17:38 #350628
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic 1979 KZ1000 cylinder PSI
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 28 Feb 2010 17:38 by Old Man Rock.
- sabell
28 Feb 2010 17:39 - 28 Feb 2010 17:39 #350629
by sabell
'78 KZ1000A2
'79 650SR
Replied by sabell on topic 1979 KZ1000 cylinder PSI
If it runs pretty good and doesn't smoke might as well enjoy it. If you are not able to ride it because of your age(14), then it might be worth while fixing it up the way you want it until you can ride it.
'78 KZ1000A2
'79 650SR
Last edit: 28 Feb 2010 17:39 by sabell.
- Kitten Tooth
- Thank you received: 10
28 Feb 2010 21:45 #350664
by Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Replied by Kitten Tooth on topic 1979 KZ1000 cylinder PSI
Well, I'll buy it. I'll do the leakdown and compression test with oil. I'll do the compression test while its cold with the oil, then i'll do it warmed up.
Thanks guys for all the info and help,
KT!!!
KT!!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- timebomb33
01 Mar 2010 17:05 #350779
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 1979 KZ1000 cylinder PSI
your motor with those kinds of numbers should be fine these motors were fairly low compression stock so those numbers aren't to far off.
