1979 KZ1000 cylinder PSI
  • Kitten Tooth
  • Topic Author
27 Feb 2010 16:50 #350434 by Kitten Tooth
1979 KZ1000 cylinder PSI was created by Kitten Tooth
Well, remember that thread i put on here about a month ago saying i was gonna get a KZ1000 but im only 14? Well, i got some bad new i guess from my mechanic about the bike. He says that it has weak cylinders... Heres the message..
"Cylinders 1&4 have 135 psi 2&3 are at 120."
Is this ok, or does it need a rebuild or something... I just sold this other bike to make the money to buy this, iv'e been waiting for ever and have been looking forward to this bike for a long long time now.. Can i buy this and have it run ok for a long time?
Thanks guys,
KT
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • TeK9iNe
  • What did you do!?!
27 Feb 2010 17:40 - 27 Feb 2010 17:43 #350445 by TeK9iNe
Replied by TeK9iNe on topic 1979 KZ1000 cylinder PSI
The valves should all be gapped correctly first, before a compression test is done.
Then, with an old air cooled bike, the compression should be tested HOT, like after a good 30min run.
I can almost guarantee that the compression would be much better, and likely much closer (within 10% numbers).
Those would be your baseline numbers.
Of course this guy wants to rebuild the engine, so he can make a $bundle$ off you, for a fairly easily performed job.
Do yourself a favor and get the bike back. Then BUY A MANUAL and start saving for some basic tools.
Good luck man!
PS. My buddy rode a 900 with barely 110 compression on all 4, for like 3 years.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 27 Feb 2010 17:43 by TeK9iNe.
27 Feb 2010 18:00 #350447 by sbc1320
Replied by sbc1320 on topic 1979 KZ1000 cylinder PSI
As long as the compression is within 15-20% it should be ok. Just put some fuel and some fire in the hole and let her rip. Good luck with it.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
27 Feb 2010 21:55 - 27 Feb 2010 21:58 #350487 by bountyhunter
Replied by bountyhunter on topic 1979 KZ1000 cylinder PSI
Thanks guys,
KT
The service limit of compresssion on a 750 twin is 115 PSI (hot) not sure about the KZ1000, I thought they ran about 20 - 30 psi higher than the 750 twins. 120 - 135 might be servicable for a while on a KZ1000 (?).
If valve gaps are OK and the compression is low, you either need a valve job or new rings (or both). First check the valve gaps and make sure clearance is good. If you can squirt some oil in the cylinders and the compression goes up significantly, that means the leak path is rings. If it doesn't go up, it's valves.
Last edit: 27 Feb 2010 21:58 by bountyhunter.
  • Kitten Tooth
  • Topic Author
27 Feb 2010 23:54 #350492 by Kitten Tooth
Replied by Kitten Tooth on topic 1979 KZ1000 cylinder PSI
what should the compression be on cylinders 1-4? I just wanna know how far off it is. I'll do the oil test. I didn't give the bike to somebody to work on, this guy is a mechanic and he wants to sell it to me. He don't seem shady at all in selling it. He told me the truth at least instead of selling me a shitbox. How do i check the valve gaps? Do i just remove the valve cover to do it? Or do i have to pull the whole frickin motor apart?:D Thanks guys
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • porchev914
28 Feb 2010 00:37 - 28 Feb 2010 00:40 #350493 by porchev914
Replied by porchev914 on topic 1979 KZ1000 cylinder PSI
Hi KT, per the Clymer manual for 73-81 kz900-1000 "normal compression should be 130-160 psi, but readings as low as 100 psi is usually sufficient for the engine to start.."
I have a '78 1000 that had compression #'s from 70 to 130 when I bought it. She smoked a bit and used a little oil, but it always started up on the first kick and never missed a beat (till I dropped a tool down the cam chain tunnel ) :angry: I bet you'll be fine with 120-135 psi till you're ready to freshen her up! B)
FRANKEN Z!
Last edit: 28 Feb 2010 00:40 by porchev914.
  • Kitten Tooth
  • Topic Author
28 Feb 2010 01:08 #350494 by Kitten Tooth
I'll do the tests... thank you for the info on the PSI. I don't have a clymer for that bike. I have one for an 81 KZ1000 but not a 79. Will my bike most likely use oil and smoke with number that low? I just got a motor rebuilt for a different bike because i didn't know how to do it myself and my wallet is empty at the moment:/
Thanks guys
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
28 Feb 2010 05:56 #350504 by roy-b-boy-b
Replied by roy-b-boy-b on topic 1979 KZ1000 cylinder PSI
If the bike has been sitting for a while the numbers could be low just from sitting.
I installed a motor last year and one cylinder had bad compression. I went to the bike shop and got some ringfree and mixed it with the next two tanks of gas and the pressure in the bad cylinder came up.
Roy
28 Feb 2010 06:05 #350505 by Old Man Rock
Replied by Old Man Rock on topic 1979 KZ1000 cylinder PSI
Unfortunately I don't have a '79 OEM manual but here's the procedure and spec for my '76 KZ900 compressions...
Standard is 121 ft pounds.
Service limit is 85 ft pounds or a difference of 14 ft lbs between any 2 cylinders.
Based on the numbers you posted and in a non warmed up fully operational engine, you may be ok for the time being.
A leak down test would also inform you of some possible issues such as worn out rings & valve seating leakage...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
28 Feb 2010 08:20 #350545 by Patton
Replied by Patton on topic 1979 KZ1000 cylinder PSI
Thanks guys,
KT
Sure wouldn't bet the farm on that mechanic's opinion. :pinch:
But can instead bet comp psi's are okay based on KHI's official FSM for 1979 KZ1000, namely:
Comp specs @ 128~156psi with service limit of 100psi and <14psi difference between cyls.
Some large four engines continue serviceable performance with even less than 100psi.
Imo, am concurring with others who suggested best to first assure valve clearances being to specs, and put some miles on your engine, before getting too excited about the measured cold comp figures, and difs between cyls.
Remember to change both oil and filter. :cheer:
Good Fortune! :)
  • Kitten Tooth
  • Topic Author
28 Feb 2010 16:55 #350618 by Kitten Tooth
Will the compression most likely get worse do you guys think? The motor doesn't smoke or anything. I'm sorry or seeming like such a noob, but how do you do a leakdown test? Oh and thanks for all the info so far..
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
28 Feb 2010 17:30 #350626 by roy-b-boy-b
I think the advice here is to ride the bike or run the bike with a fan blowing on it and let the rings have a chance to warm and expand.
Leak down test can be found with the search function. Roy
