- Thank you received: 1
Valve seal install?
- polkat
And should I use some kind of protection sleave when I push them over the valve stems? Thanks!
- KLD
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
West Linn, OR
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- polkat
By the way, in cars we usually get a clear plastic sleeve with the seals. It is put over the stems to protect the seals from sharp edges when installing. Is this necessary with bike engines?
- APE Jay
- Banned
- Thank you received: 58
Once on the guide, valve stem is removed and springs does not pop off.
- Skyman
You weren't kidding! I nearly had to chisel them off!
I use one of those hook & pick tools to get under the lower lip of the seal and pull it up.
I never used anything like that, nor have I ever seen them.
West Linn, OR
- BSKZ650
- Thank you received: 14
they only seem to last on a couple of valves.
77 ltd1000, current rider
76 kz900, just waiting
- BIGD
Had 1981 KZ1000 M1 From 1981-1995 Canadian Model
Have 1981 KZ1000 M1 US Model
- timebomb33
- larrycavan
- Visitor
OEM seals are the only way to go IMO. They won't deform from installation and the clip does't pop off either.
Most aftermarket seals are 100% junk and not worth the time & money to install if you expcet any life out of them.
OEM Kaw seals cost more and they'r worth every extra dollar
I recently got a head in with metal jacketed valve seals like Suzuki uses. They are a bugger to get off sometimes.
With Kaw seals, to remove, push the clip off the seal first. Then grab the seal with needle nose pliers, twist it to brake it loose, the twist & pull it right off the guide.
- timebomb33
