- Thank you received: 2098
Valve seal install?
10 Mar 2010 04:45 - 10 Mar 2010 05:01 #352381
by Patton
Replied by Patton on topic Valve seal install?
Last edit: 10 Mar 2010 05:01 by Patton.
- larrycavan
- Visitor
11 Mar 2010 05:03 #352611
by larrycavan
Replied by larrycavan on topic Valve seal install?
timebomb33 wrote:
That might be the ticket for those metal jacket seals Tim.
Fortunately, they're few and far between
larry you should try small hose pliers you will be a changed man after trying them. they are just the right size have decent teeth on the jaws and are bent just perfect for valve seal removel in fact they should be called valve seal pliers instead of hose pliers most times they just chew the hose up.
- mark1122
- Keep twisting it
- Thank you received: 109
11 Mar 2010 07:24 #352644
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Valve seal install?
i place the valve in the guide first. then after lubing the seal i slide it over the valve stem and then down over the guide. i find the valve stem,just helps to keep the seal centered while u push it onto the guide.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
