- Thank you received: 72
vintage 750 (now 810) racer
- turboguzzi
getting to like the thing and seeing the kind of numbers people seem to be getting, i am starting to consider building the GPZ itself as an 810 (or more?) to compete in the up to 83' open class rather than slotting the top end on the KZ650 and run it as a 750 in the 750 class.
In the open class I'll be up against 110-120 hp GS1000 and KZ100's but with a light monoshock thing with 100hp, maybe it's a better bet. We have just one top speed track where it would be at disadvantage, but on the other slower tracks, an 810 could be the hot ticket. got to think about it.
cheers
TG
- thompsonmx100
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
- turboguzzi
Well I'm waiting for pics. So are you gonna mono shock the thing or whats your plan?
Battey charger found, so soon will be pics,
plans are a bit fluid/confused at the moment. initially I wanted to build a 750 racer with a KZ650 I am picking in three weeks and hop it up with parts from the GPZ I've already got.
Then, when I found out that a new open class with a cut off date of 1983 has been established this year, I am starting to consider building the GPZ as a 810 by itself.
got to decide.
nice problem to have
TG
- turboguzzi
The italian federation has changed the cut-off date for the open class, so now the 1983 GPZ is allowed and I will eventually run it as open class 810.
While dismantling it I have found it to be so race ready, it will take a lot less work to get track worthy. Frame is super braced as is, gonna change the soft mounts to solid for more rigidity (unless someone has a reason why not)
Reading the gpz750 mods FAQ i tried a GSXR750 rear shock for size and its a 15 minutes job to get it to fit. Chalk one up already!
Here are some pics, in the meantime i want to sort out an adjustable length link for the suspension so I can easily change the rear height.
more info will follow
- turboguzzi
- larrycavan
- Visitor
It's quite common to find the valve seats chipped very badly around the outside edge.
On a stock motor, it probablly won't show as a problem during compression or leak down testing because the 45 is usually not chipped yet. It's right on the edge of desctruction though.
If the intented use of the bike is racing with lots of high RPM, the situation will likely progress.
I only see this problem in 750 Kawasaki 4 cylinder engines.
It may not be noticable until you pull the valves and blast out the combustion chambers. Then it shows up plain as day.
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- thompsonmx100
1985 gpz750
Kz 650
- turboguzzi
the shock is from a 1993 GSXR750WP. It's 312mm long compared to the 309mm stock. Had only to narrow the top eyelet bushing to make it go in, bottom clevis hole had to be opened up to 12mm + some shims added as its wider too.
dont know if i want to go too crazy with an s'arm swap, the italian vintage association is quite stiff as to waht mods are allowed, parts form bikes not belonging to the period (up to 83' in my case) are not happily accepted. 17" wheels and floating discs are a no-no.
Not complaining, I think it levels the field and maintains those bike's character.
Wil certainly keep updating.
Cheers
TG
- thompsonmx100
1985 gpz750
Kz 650
- turboguzzi
For good or bad, italy is a very conservative place and it is reflected also in how they approach vintage racing.
for instance, also on the street, a non approved, noisy exhaust system will get you a heavy fine, change tire sizes they will confiscate the bike for illegal changes.
The good side, the food is so good just because they stick to all the old recipes and have perfected them, and the way they keep and restore all ancient buildings is inspiring.
You just have to accept it all if you want to live here.
TG
- Old Man Rock
- Thank you received: 225
Yeah sure, must be a bummer to live there... Truly, wholly freaking aye... Smoking Hot Italiano babe....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
