- Thank you received: 44
ape cam tensioner yeh or nay
- jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Samwell
- Thank you received: 1
i have succesfully adjusted my valve clearances and now the only thing i hear is the cam chain on my 2001 kzp and it looks like i am leaking oil there!i have read some old posts and am curious if any of you guys have had good luck with that ape manual tensioner?i think i would like to know with certainty whether or not i have proper tension there and maybe it will quite it down a bit.thanks for any advise and i really appreciate all of the tips you guys gave me on my valve adjustments!
I vote Yeh! for the manual tensioner. the stock has spring loaded ball bearings that wear down and doesn't hold tension like it should. the manual one requires checking every so often, but won't go slack on you.
my 2 cents
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Just be sure to re-tension them periodically. More frequently on a new chain of course.
Myself, I set the engine to TDC 1-4 and then turn in tensioner while rocking the chain back and forth gently via a breaker and 17mm socket on the crank.
Just finger tight!
Takes all the slack up in the chain this way.
Then back off about 1/8th turn.
Thats it. Done. No rattle anywhere and it actually makes a difference in the power delivery you can feel.
Even if it is slightly tight, it wont be for long...
WOTshiftWOTshiftWOTshiftWOTshiftWOT... mirror :laugh:
GL
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- fweep
- 2001 ZRX1200R, 1991 KZ1000P, 1984 V45 Honda magna
Works fine. I think the OEM has an O-ring as well if I remember correctly.
- scubarod
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- scubarod
- fweep
When I installed the APE tensioner on my '91 KZP, I followed the instructions and then had to "play" with it a bit.
I had it set and then I would ride and not like the noise so I would adjust the tensioner tighter and that actually made more noise.
With the engine running I ended up backing off the tensioner until I hardly heard any noise and then tightened it very slightly. I did this a couple of times until I got it to where I thought it was best.
There is still some cam chain noise as it runs over the guides and has the "singing" or " cricket" sound.
But it used to sound like the cam chain was slapping around as it went around.
I hope this helps.
You may also want to check out the Yahoo KZP forum:
autos.groups.yahoo.com/group/kz1000p/messages
As that is a KZP specific site. That is where I decided to try the Ape tensioner.
Good luck and ride safe!
Bill
- scubarod
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
'85 GPz550(ZX550-A2)
