- Thank you received: 8
wiseco 1015 suprise!
- tfh903
17 Feb 2010 17:38 #348870
by tfh903
Replied by tfh903 on topic wiseco 1015 suprise!
My wisco 1015 pistons with numbers on the dome came with instructions that say the clearance for the pistons are .0015" - .0025" / 0.04 - 0.06mm .. The ring end gap should be.004" for every inch of bore size ie: 1015 is about .012"..
suggeston.. think about having the skirts and dome coated. I had mine done and it cost about 160.00 for the set. The skirt coating relieves the friction on the walls and the coating on the dome gives a better, more unform burn in the combuston chamber as well as protects the piston from the heat. contact Carl at www.polydyn.com (I think that is the address). B)
- APE Jay
- Banned
- Thank you received: 58
17 Feb 2010 23:06 #348910
by APE Jay
Replied by APE Jay on topic wiseco 1015 suprise!
toad wrote:
That is the forging number. All Wisecos have had a letter stamped on the top, that designates the ring style
no mine are not stamped on top but rather there is a stamp inside them on each side of the pin 4020-W
- toad
- Thank you received: 7
18 Feb 2010 07:25 #348962
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Replied by toad on topic wiseco 1015 suprise!
yes mine have the letter C
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
