- Thank you received: 7
wiseco 1015 suprise!
- toad
15 Feb 2010 06:56 - 15 Feb 2010 08:03 #348425
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiseco 1015 suprise! was created by toad
I pulled my motor and tore it down out of my kz900 and needless to say I believe I have wiseco pistons 1015.They have a stamp inside 4020 and a w.Is this correct?If so where could I buy a new set of rings for them?Also I only no tolerances for the 900 ,not the 1015.Could someone please tell me the bore to piston tolerance for this application, like how much play would be allowed to consider reusing these because they do appear to be in good shape, a quick measurement and they read 70mm.I also have a stock 900 gasket set or do I have to use the wiseco gaskets.
Sorry for all the questions,thanks for all the help!
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Last edit: 15 Feb 2010 08:03 by toad.
- Jeff.Saunders
15 Feb 2010 08:04 #348442
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic wiseco 1015 suprise!
The key is going to be the age of the Wiseco pistons. Wiseco changed ring groove size over the years.
The current setup has 1mm top, 1.2mm middle, and 2.8mm oil control ring.
Z1 Ent on Facebook,
- toad
15 Feb 2010 08:22 - 15 Feb 2010 08:39 #348443
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Replied by toad on topic wiseco 1015 suprise!
Oh Oh this sounds bad..I'll start measuring
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Last edit: 15 Feb 2010 08:39 by toad.
- Jeff.Saunders
15 Feb 2010 08:31 - 15 Feb 2010 08:31 #348445
by Jeff.Saunders
Z1 Ent on Facebook,
It can be a problem, or it might not be. For one customer with a very nice set of old Wiseco pistons, he used the top two rings from our 70mm aftermarket oem replacement rings and reused the old oil control rings.
Z1 Ent on Facebook,
Last edit: 15 Feb 2010 08:31 by Jeff.Saunders.
- toad
15 Feb 2010 08:43 #348447
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Using the old oil control rings isn't a big deal then.Or does your replacement rings come with them as well?
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- toad
15 Feb 2010 09:36 - 15 Feb 2010 09:45 #348452
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Last edit: 15 Feb 2010 09:45 by toad.
- Jack
15 Feb 2010 13:36 #348474
by Jack
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Replied by Jack on topic wiseco 1015 suprise!
Jeff at Z1 seems to have the fix. If not, I've had good luck finding rings for old or oddball pistons including Wiseco & MTC from TotalSeal. You'll need the ring land dimensions as well as the 70mm. bore.
www.totalseal.com
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- toad
15 Feb 2010 17:32 - 15 Feb 2010 17:40 #348519
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
thanks guys, I will also go get the bores measured,what bore to piston measurement would be tolerable for the 1015 anybody?
Or is it the same tolerances as the 903
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Last edit: 15 Feb 2010 17:40 by toad.
- porchev914
- Thank you received: 19
16 Feb 2010 00:07 #348580
by porchev914
FRANKEN Z!
Replied by porchev914 on topic wiseco 1015 suprise!
I'm not sure if Wiseco has changed their aluminum formula, but I just brought home a set of 1075 Wiseco pistons today, and the sticker on the box says .0020" or .051mm. I hope someone with more knowlege of Wiseco pistons can confirm or refute this :dry:
FRANKEN Z!
- APE Jay
- Banned
- Thank you received: 58
16 Feb 2010 00:35 #348581
by APE Jay
Replied by APE Jay on topic wiseco 1015 suprise!
Wiseco puts .002' on everything. We set 1015s up at .0015" . Youcould get away with running those with up to .003"
- Old Man Rock
- Thank you received: 225
16 Feb 2010 01:56 - 16 Feb 2010 02:01 #348582
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic wiseco 1015 suprise!
This image was taken 7-12-2008 of my Wiseco 1015cc kit with rings # 2756XC... Fairly newer Wiseco stamps the piston numbers across the domes.
Your pistons look like this one (outside of carbon build up of course)?
Maybe a picture of the cleaned piston would help these guys...
Follow the links to download the Wiseco Piston Ring Catalog...
www.pistons-online.com/
www.wiseco.com/PDFs/Catalogs/CB07/Comp-Rings.pdf
www.wiseco.com/PDFs/Manuals/RingEndGap.pdf
Just a thought...
OMR
Just a thought...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 16 Feb 2010 02:01 by Old Man Rock.
- toad
16 Feb 2010 06:40 #348597
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
no mine are not stamped on top but rather there is a stamp inside them on each side of the pin 4020-W
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
