- Thank you received: 1
Good piston ring land solvent?
- polkat
12 Feb 2010 22:47 - 12 Feb 2010 22:50 #347981
by polkat
Good piston ring land solvent? was created by polkat
My 750-4 pistons were well covered with carbon when I tore the engine apart. I cleaned them up and they look pretty good.
However, while the new compression rings fit, they fit a bit tightly (they are the right rings), and the clearance seems minimal (a little smaller then it should be). I had cleaned the ring lands with a broken ring (cheap approach but usually works), but I can still see a lot of what looks like carbon/varnish on the flats inside the lands, which I can't seem to scrape out with the broken ring (and I don't want to grind around in there with it!).
Is there a solvent of some kind that will clean the lands out well, that is safe on aluminum?
Last edit: 12 Feb 2010 22:50 by polkat.
- bountyhunter
- Thank you received: 337
12 Feb 2010 22:50 - 12 Feb 2010 22:59 #347982
by bountyhunter
Replied by bountyhunter on topic Good piston ring land solvent?
I use a Berryman's dip tank for cleaning stuff, and it works well on hard burned carbon gunk (if you leave it in a few dys). It's got to be safe for aluminum to dip carburetors, but it will eat most plastics.
You might be able to make a tool out of a popsicle stick that could scrub inside the grooves without damagine the aluminum.
Last edit: 12 Feb 2010 22:59 by bountyhunter.
- Thank you received: 2098
13 Feb 2010 04:00 - 13 Feb 2010 04:04 #347992
by Patton
Replied by Patton on topic Good piston ring land solvent?
Yamaha Ring Free, available at Yamaha dealerships, enjoys a good reputation.
But don't know how effective it might be in this particular situation as a possible carbon solvent for direct application.
Click here > Ring Free
Good Luck!
Good Luck!
Last edit: 13 Feb 2010 04:04 by Patton.
- snorules
13 Feb 2010 04:17 #347993
by snorules
1980 KZ550C (daily rider)
1981 KZ1000J (bagger project in progress)
1981 GS1100 (future dragbike)
1978 Z1R (not mine yet, but trying to work out a deal to acquire it).
Replied by snorules on topic Good piston ring land solvent?
I use plain old paint thinner from walmart as solvent. Works like a champ, and it's cheap ($8.00 a gallon). I found an old ceramic coated pot in the storage shed that holds about 2 1/2 gallons. I just rebuilt a Mojave 4-wheeler, I used my makeshift solvent tank to clean the engine parts. The head came spotlessly clean using a toothbrush and the thinner. I soaked the stripped down head for a few minutes, then started scrubbing away. All of the old gunk and carbon deposits came right off, even from the exhaust ports and combustion chamber! After it's clean, blow dry it with compressed air and BAM, done.
- Old Man Rock
- Thank you received: 225
13 Feb 2010 07:09 #348020
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Good piston ring land solvent?
Question...
Would soaking them in Seafoam work as a solvent cleaner?
Since they work on a running engine to clean carbon build up why wouldn't soaking do the trick as well... Hmmm, me wonder...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- APE Jay
- Banned
- Thank you received: 58
13 Feb 2010 10:20 #348064
by APE Jay
Replied by APE Jay on topic Good piston ring land solvent?
Full strength Simple Green.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
13 Feb 2010 10:33 #348066
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Good piston ring land solvent?
Old Man Rock wrote:
The seafoam works great with a little fuel as well.
Question...
OMR
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
